Sujestion for new skin of radio boss
What about the case when those items are scheduled? Should they have the "Clock" icon added to them (as it happens now with "Music note" icon) or should just those custom icons be used?
I think it should stay as it is now.
To differentiate, I’m not sure if it would be better to use an hourglass icon or some other icon that indicates that there are scheduled items. But for me, it’s fine the way it currently is.
Some ideas can be taken from this software called Salamandra. It’s still in development, and it’s inspired by Radioboss and Zara Studio.
I like its visual interface, which is NOT very different from RADIOBOSS. I think we could take some ideas from this software because it looks very good visually.
Specifically, the way the current track, the time, the date, the temperature, and the humidity are displayed is very well organized.
Additionally, some icon ideas like these:
Olá equipe de suporte, estou sugerindo a você, equipe Radio Boss, que modifique a skin Radio Boss para um formato mais profissional. Vejo que outros programas de automação melhoraram muito nesse aspecto, e embora seja tudo uma questão de marketing visual, eu não trocaria o Radio Boss por outro, mas gostaria de vê-lo renovado, com uma skin moderna e bonita. Se puder, ficaríamos felizes, porque estamos quase em 2026 e nada mudou em sua essência visual... Analise essa possibilidade, pois assim você venderá muito mais do programa de automação.
Aguarde nosso software que será lançado neste final de semana, Sao 16 temas de cores e mais 5 layouts, Muda apenas com um clique. Quaquer duvida. [advert link removed]
Some elements not previously mentioned would be:
Icons for the following items:
playlist, station ID, folders (tracklists), teasers, commercials, commands, comments, etc.
What if it's implemented as a secondary icon, e.g. in the "Title" column or wherever. In this case, the standard icons will remain so that you can see played/scheduled/other statuses and at the same time, see another icon to better distinguish the file type/item type? In this case, we won't need to create additional states (scheduled/played/...) for custom icons.
The interface is a copy-paste of RadioBOSS 🤷‍♂️ (and, like any software today, is black). Minor changes here and there, but this is a copy still. I honestly do not see what is "new" here, moving the temperature from left to the right in certainly not an innovation.
Well, menu icons for every command is what was in the UI design guides in the beginning of 2000s. RadioBOSS also did use menu icons in the past; nowadays it looks bloated and outdated - and, in most cases, those icons do not add any additional value/information. E.g. on your screenshot, "Add random track" has a folder with a note icon - how is this associated with randomness?
But I agree some more UI icons, like for weather display, can be useful and refresh the UI. Maybe for certain menu commands as well. Or custom icons for playlist/zone tabs.
Some of the changes will be implemented in the upcoming RadioBOSS 7.2.
I think it could be tried. I currently use emojis, as I show in the screenshot, to distinguish the items, but they don’t display in color. Also, in each filename I have to add an emoji to tell what type of item it is. Doing this is a bit annoying because it takes a lot of time.
I think what you’re suggesting would be fine. In that case, they should be configured for each file type, and Radioboss should already have the corresponding icons set by default.
Yes, that’s true. But I think the empty spaces at the top of the interface could be used; placing the time and date in a larger size would look better for the user
The menu icons certainly aren’t necessary — I was referring more to the idea of icons that can be used for the items; I didn’t specify that, sorry.
Yes, I think it’s great to have icons in the tabs for the work areas, playlist, etc. It would save space by placing icons instead of writing a name on the tabs. Some time ago, I requested that the emojis be shown in color, since I currently use emojis for that. But it’s also necessary to set the tab width to match the icon.
If you have something better in mind, then coloring the emojis wouldn’t be necessary.
Support for color emojis may also be added, I marked it for RadioBOSS 7.2.
Yes, ready icons, as it would be pretty inconvenient to load your own icons.
Color emojis and icons for tabs will also be supported in RadioBOSS 7.2 as a part of updating the UI, and icons too, so you can decide what to use.
There will also be changes, as according to this thread, RadioBOSS's UI definitely needs a refresh. Work is being done in this direction already.
Great! I'm eagerly waiting for the upcoming RadioBOSS 7.2 update. Do you have any estimate of when this version might be released, or whether it will be available as a beta first?
What could also be cool is an icon for when tracks have had the segue editor applied to them. See example from Zetta. Would be handy to visually see what's been done/not done. I guess it would be hard to tell which track to apply it to. The start track, the middle track, the end track? All 3? Not too sure...
If I remember correctly, there should be in the options to display in the column, also the "edited" checkbox which is displayed with a black dot ⚫
There's a column for this called "Segue Editor", it will show a black dot when a track was edited with the Segue Editor. You can choose what columns to show in the playlist by right-clicking on a playlist column header.
Oh sick! Thank you! Although, it shoes if there is a mix marker on the track. Like we have mix points on all ours tracks by default, it shows it all the time, even if we haven't used the segue editor at all. Maybe it can deffienciate between a mix point made from the track tool and one made by the segue editor?
The column is called "Custom mix" (previous post edited) but it actually shows if mixing was edited using the Segue Editor, if you set the Mix point via Track Tool or use the Process Tracks in Music Library, the column will not show it. It will only show a mark if anything was edited using the Segue Editor (or you merely called it and clicked OK, this is also registered as customized mix).
For me, Radio Boss is undoubtedly the best program in the world for web radios; there's nothing like it. I only suggested skin modifications and a virtual mixing console for those who don't have an external console, making it easier to use on tablets or another screen to manipulate the virtual console. It would look modern and very beautiful, even surpassing some competitors and focusing attention on us, Radio Boss. Because everyone who has used Radio Boss to this day is already loyal to the software. My gratitude to the entire Radio Boss team, who are very competent.
I've also been very happy using it since 2020. I've regularly extended all my licenses for all DJ SOFT products, because it's worth every penny.
I'll buy RB Cloud later for completeness.
Many thanks to the staff and developers who read us, respond, and develop new features every day.:cool:
I would like to take this opportunity to point out that there are still display issues when using Remote Desktop with a 2K or 4K screen and then switching back to a Full HD screen. It would be great if RadioBoss were a little more responsive.
Thank you in advance
