Altec
Hi Dmitriy,
Sometimes my playlist generator creates playlists that are a little too short, which causes silences on the air and triggers my backup system.
I think this is because the Pl Generator does not take into account the actual length of the track based on the start, mix and end points defined in the track tool. I noticed that this problem of playlists being too short occurred when I had several tracks configured like this, for example, in one hour:
Can you confirm how the Playlist Generator calculates the duration of an hour?
To avoid silence detector I set playlist duration at 01:03:00 into Pi Generator.
Best Regards
Best Regards
