Playlist Generator Pro : Does the playlist generator take into account the real length of the tracks between the start and end points?
Altec
Hi Dmitriy,
Sometimes my playlist generator creates playlists that are a little too short, which causes silences on the air and triggers my backup system.
I think this is because the Pl Generator does not take into account the actual length of the track based on the start, mix and end points defined in the track tool. I noticed that this problem of playlists being too short occurred when I had several tracks configured like this, for example, in one hour:
Can you confirm how the Playlist Generator calculates the duration of an hour?
To avoid silence detector I set playlist duration at 01:03:00 into Pi Generator.
Best Regards
The Playlist Generator does read this information. But if some music tracks do not have those points set, and Gap Killer feature removes the silence on playback, the playlist may become shorter a little. Same for the Mix point, especially if you have the "Trigger mix" option enabled, and tracks do not have a Mix point set (in this case it's also detected on playback).
In my case, all the start and end points are clearly defined for the tracks in the hour in question. So perhaps it's a bug?
I know all that, which is why I took the liberty of writing to you, because there is no reason why the Pi Generator should have made a shorter playlist.
Best Regards
Do you use the latest version of RadioBOSS? Please also check about the Mix point as it also affects the duration.
Yeah, this the latest version and all Mix and End points are set... i don't understand
They must also be set for station IDs and other things. In any case, it's a good practice to make the playlist generator create a playlist that's 2-5 minutes longer than needed.
Every tracks played in my studios are configured in Track Tool before.
Are you sure that Playlist Generator is taking into account the end point and not the real lenght of the track because I have many silence detector in another RadioBoss playing a webradio with some long dj Remixes I have configured to be shorter, like in this example :
If plyalist generator consider this as a 4minutes tracks it's not good and he gonna generate a too short playlist. He should considere in that case a 1:34 track.
best
Yes, but I'll add it to be checked. I'm also not sure if it does consider Mix point - this will also be checked for the next RadioBOSS 7.2 update.
Thank you Very Much Dmitriy.
I wanted to know if there is a way to Donate somewhere to thank you for taking in considerations our request and to developp things for us ?
Best
There's no need in donations because RadioBOSS is a commercial software with a paid update subscription :) Keeping your subscription active is good enough. And of course good words always help too (y)
Yes, I'm renewing each year my licences subscriptions but I wanted to do some more to thank you for your constant support and consideration for all our ideas and feature requests.
Best regards
