Nomenclature of playlists generated by the Ads Scheduler
Altec
Hello Dmitriy,
I would like to ask you something quite simple but necessary and not possible at the moment.
Would it be possible to generate playlists with the Ads Scheduler using the following nomenclature:
%y%m%d_%h_%m_INTERNALADS
Example :
251219_10_12_INTERNALADS.m3u8
This would make RadioBoss compatible and missible with my external advertising spot management solutions.
Best Regards
Altec
I'm not sure why is it not possible? If you specify the playlist format file name as on your screenshot, it will create the file names as you need.
I have the same request, but it is not working.
The software does not seem to want to interpret the date : %y%m%d
It should also be noted that if you want to program the screens (spot) yourself in order to create complex screens, RadioBoss will always try to insert them into the programmer itself by default.
For my part, I work with complex screens using both internal and external playout systems through an on‑demand call solution such as %yyyy%mm%dd_%h_%m_regie1.m3u8 and %yyyy%mm%dd_%h_%m_regie2.m3u8... This generates many errors in the studios when there are no ads in the m3u8 files, even though this is not actually an error — it simply means that there is no advertising to broadcast.Perhaps there could be a way to exclude these errors when working in this mode, so that the studios are not flooded with unnecessary error messages.
I see, the Ad Scheduler has limited support for the templates. Currently, it only supports those variables: %n, %d, %h, %m. We'll extend this in the next update to allow specifying a year, a month, etc.
This is good news.
Thank you for listening and for your help.
I wanted to bring up something I've noticed while managing ad screens manually.
When we set up ad slots from different providers (like Regie A, Regie B, etc.), we use playlist files named something like:
%yyyy%mm%dd_%h_%m_regie_A.m3u8
%yyyy%mm%dd_%h_%m_regie_B.m3u8
Sometimes, if a provider doesn’t send any ads for a certain slot, the .m3u8 file ends up empty. When RadioBoss tries to play it, it sees the empty file and logs it as an error in the reports.
But really, this isn’t an error – it just means there were no ads from that provider at that time. It would be great if RadioBoss could recognize that an empty playlist isn’t necessarily a playback error, but just a normal "no ads to play" situation. Maybe adding a note or a different status for this would help clean up the reports and reduce false alerts.
On a related note, it would also be really useful for our billing and reporting if we could generate separate playback reports for each individual ad provider (Regie). This way, we could easily credit the correct broadcast of their spots by date and time for invoicing and verification.
Thanks again for your time and all the great work you do!
There's an option in Ads Scheduler Settings - "Generate playlists for empty blocks" if you disable it, no playlist and no event to start this playlist, will be created.
It should actually log not as an error, but like "Playlist ... loaded, 0 tracks" and then the next track in the playlist will play, with no error messages. Can you please post a screenshot of an error message that it shows you?
One way to achieve this would be to create separate "Commercial" file type for each provider, and then in the Report Generator select in the filters to report only this file type: https://manual.djsoft.net/radioboss/en/report_generator.htm
Faites attention dans mon cas, c’est différent : les publicités ne sont pas générées par le planificateur de RadioBOSS, mais par un logiciel tiers qui crée des playlists m3u8 complexes.
Be careful in my case, it's different the ads are not generated by RadioBOSS's ad scheduler, but by a third-party software that creates complex m3u8 playlists.
Then the software should be instructed to not include links to invalid items in the playlist. When RadioBOSS encounters an item that it can't play (e.g. the file does not exist) it will report an error of course.
Do you mean that we can set a value or leave the m3u8 without an audio file so that RadioBOSS doesn't perceive it as an error but simply sees that there was nothing to play?
I haven’t found any command to automatically extract reports with predefined settings using the report_generator. Is this possible ?
It should be possible to update the m3u8 files without this action automatically inserting the schedules into the scheduler on the left side in RadioBOSS.
Yes, an empty file will not result in an error, because an empty playlist is still a valid playlist.
The Report Generator has command line options if you want to automate reports creation: https://manual.djsoft.net/radioboss/en/command-line.htm
It doesn't insert anything into RadioBOSS playlist, this option only updates the events in the events list, it does not start anything or do any other modifications. Maybe when you run the update command, it's also time to start one of the scheduled ads blocks, so this is what happens. You can see it in the Log window (bottom left corner).
Should I understand that the “adsupdate” command is not meant to update the advertising screens scheduled in the m3u8 files? Does this mean that the software updates the m3u8 files automatically, without needing to send a command or press a button in Ads Scheduler?
Let’s take a concrete example so I can be sure I understand correctly. I schedule my ads for the whole month. Ads Scheduler then creates one week of programming and generates the m3u8 files for days 1 to 7. The following week, if I don’t touch Ads Scheduler at all, will it automatically replace the ads with the new ones for that week?
I’ve found a software bug. I just realized that when I launch ReportViewer.exe through the shortcut, it doesn’t load the studio arguments.
I have to open it directly from the studio for it to communicate properly.
As a result, the CMD can’t extract the data from the studio.
On the left, ReportViewer.exe opened from the shortcut; on the right, ReportViewer.exe opened from the Radioboss studio.
Because of this, my command doesn’t work:“\\192.168.1.101\nas\RADIOBOSS\RB_STUDIOS\XX_DAB\PGM_FR\ReportViewer.exe" --create="\\192.168.1.101\nas\REGIES\LOGS\LOGS_RB_RAPPORTS_CSV\rapport-$(Get-Date -f 'yyyy-MM')|PDF|2026-01-01|2026-01-31|List|0,1,6"
The following screenshot shows both ReportViewer.exe processes running at the same time — one launched through the shortcut and the other from the studio. You can clearly see that the AppData arguments are missing in the instance started from the shortcut.
This command will update the playlists (.m3u8 files) and events in RadioBOSS's scheduler.
If you don't call this command or export manually from the Ads Scheduler, then the events/playlists will not be updated/created.
It will not replace because you didn't instruct it to, it will run the same ads over and over. Depending on your configuration, you should run the adsupdate command periodically (every day or every hour).
It's explained in the user manual: https://manual.djsoft.net/radioboss/en/automatically-update-ads-playl.htm
It should read the last profile that was used in RadioBOSS. We'll check if there's a bug preventing this from happening.
