RadioBOSS 7.2 [beta]
Hello, I have installed version 2.7 [o 7.2]. I am encountering an error when trying to record a Voice Track; I am attaching the images so you can help me find a solution to this problem.
Additionally, I noticed that the File Type icons are not being saved. When I change the file type of a track, the assigned icon does not remain stored after the change.
Thank you in advance for your help.
I would like to suggest a couple of features for future updates:
  1. Video Watermarking: It would be great to have an option to overlay the radio station logo directly onto the video playback window.
  2. Dynamic Titles: An option to display the Artist and Title of the song/video on screen. Ideally, with a timer to show the info for 10 seconds at the start and 10 seconds before the track ends.
On another note, the segmentation in Track Tool for specific days of the week and hours is excellent. Great job on that feature! 👍
Another great addition to the Track Tool would be ensuring that Start, Intro, Outro, End, and Mix markers are fully active for both audio and MP4 video files. Having full feature parity for video files would be a huge improvement.
Thanks! I’m still testing this version.
The way I see... Playlist generator pro will just have to have a new tab just for assigning different clocks/presets to the different hours of day. Generate all playlists for the 24 hours once and they're loaded into the scheduler section to load at their play hours... Just like the Ad scheduler. Just saying.
Would indeed be helpful. Kind of like what you might see in some automation systems (examples attached for reference). Or what Radioboss does in ad scheduler as you said, but for clocks/presets instead of ads. Events can then be automatically created and scheduled as it would be synced with the event scheduler. Could be implemented as an extra tab in the Playlist Generator.
run PlaylistGeneratorPro.exe "-preset=Funky" "-out=C:\Users\tomim\Downloads\Funky.m3u8"
…and then repeat this for all presets.
If this is to create playlists for all day, better would be to create all paylists in one go, as this way they will all share the same repeat protection buffer. In the playlist generator, click the arrow near the Generate button and select "Create multiple playlists". It will create the command for you.
In my case, this would mean around 77 generate commands/lines inside a single event. I don’t consider this an edge case — in practice, most reasonably serious radio stations operate with a large number of presets, not just 5–10, unless the format is very simple or narrowly specialized (for example, a pure hit radio).
This is not a problem, the number of playlists is not limited, but as I say, it's better to create them in one command.
Is there any command, option, or mechanism that would allow generating playlists from all presets that exist in Playlist Generator (or from the folder where .genprs are stored), without explicitly listing every preset name and having to constantly maintain those lines manually?
This is what the new tool (the one I wrote couple of posts before) would allow to do.
About the generate command. We have found a solution to improve this command, allowing it to use the new features, as well as get rid of the "unpredictable start time" problem. The command (event) will have an option to "start creating playlist X minutes before its start time". This way, it's only a single event, generate-and-start, and it would be known when the playlist will launch.
In practice, this means I can only end up with static names like Pop_mon_16.00, Rock_sun_13.00, Swing_sat_12.00... which again leads to a folder full of files without a clear way to verify that every hour is covered.
If I want to cover every hour of the week, that would mean 24 × 7 = 168 such time-based M3U files, right? Ufff...
Templates can also use folders, you can have a separate folder for each day of the week, containing only 24 playlists. Again, this is what the new tool (to manage playlists) will allow easily to do and overview.
Simply load the preset for each hour and RB takes care of the rest :)
I hope we can see something like this in this Beta
This is a completely new tool, and all major features for this beta are already added. But about tool like this, it can be released as a part of intermediate beta, with the only new feature is this new instrument.
Buen día, quiero informarles que en esta versión de prueba, estoy experimentando un comportamiento aleatorio e impredecible en el software. De repente, sin realizar ninguna modificación, aparece este error: el tamaño de la fuente cambia inesperadamente y, al intentar restablecerlo, no puedo deshacer el cambio.
Please write in English.
Yes, this is a bug, please change some other file type option to make it save the icon.
We have this feature planned for one of the future updates.
Something like this would be added too, but this is going to happen in one of the next major updates, as it requires lots of changes to video processing.
Thank you!
This is not really possible now due to technical limitations on how the videos are played, especially mixing is tricky.
This is going to be added in one of the next updates, I think it may be a separate release with this tool included. This is going to be available in Ultimate only.
I think we’re speaking from two completely different perspectives.
From a developer’s point of view, the answer is: “Yes, this is possible, RadioBOSS can do it.”
From the day-to-day reality of running a radio station, the answer becomes: “Yes, RadioBOSS can do it, but the workflow is so complex that it’s close to unusable in everyday operation.”
When I say that in practice this means 77 presets → 77 lines/definitions inside one event (or spread across multiple events), the response is essentially “RadioBOSS can handle that.”
My point is: RadioBOSS may handle it, but the operator still has to maintain it. With larger setups, this quickly becomes fragile and error-prone.
You suggested using Create Multiple Playlists. Yes, that is technically possible, but the workflow then becomes:
- first, create and maintain all presets
- then use “Create Multiple Playlists”, which still requires explicitly selecting each preset and manually assigning an output name for every generated playlist
- then create an event that generates a large number of M3U files
- and only after that create additional events to load and start those generated playlists
For something that used to be straightforward, this is a significant increase in complexity and maintenance.
You also mentioned that these changes were needed to ensure precise timing.
However, users who needed that level of precision already had it before by using “Save generated playlist to a file.”
Users who didn’t need that level of precision could simply use the Generate preset workflow.
Now the simpler option is gone, and everyone is forced into the more complex “generate-to-file” approach.
So this doesn’t really add precision — precision already existed — it removes choice and pushes everyday operation into a much more complicated and messy process.
Dayparting itself is a nice feature, but in this model it effectively requires working with timestamped M3U files. In real-world radio operation, this becomes impractical very quickly.
For a weekly schedule, we’re talking about 7 × 24 = 168 time slots.
With time-based playlist files, you end up with folders full of M3Us, and there is no clear or reliable way to verify at a glance that every hour is actually covered and nothing is missing.
Your suggestion to split this into 7 folders (one per day, 24 playlists each) doesn’t really solve the problem — it just spreads the same complexity across multiple folders.
It still doesn’t provide a clear overview of coverage and makes it easy to miss a missing hour or a misconfigured event.
I’d also like to clarify that UI cosmetics (icons, emojis in tabs, nicer clocks, visual tweaks) are not what I’m looking for. Nice to have, but...
What I need is a system that works reliably, is logical, easy to maintain, and easy to oversee in daily operation.
I need a playlist generator, dayparting, and rules like do not repeat (including for intros) that solve real programming problems without adding operational complexity.
At times, it gives me the impression that some changes are being pushed mainly to ship a new version with new features, rather than because the overall workflow is fully thought through and ready for real-world use.
From an operator’s perspective, parts of this feel unfinished rather than truly complete.
This approach may work for a small internet radio or a very simple 24 hour playlist, but for a normal, full-format radio station with structured programming, it’s simply not practical.
There's a problem with the `writetag` command. Has something changed in its structure? My programs aren't working in this beta version. But they work when I try the latest stable version.
Some of my Tags don't seem to be setting for example my new Clean Tag sets fine, but the new EXPLICIT tag i created won't set atleast visually its there in the tags when viewing track editor/track properties but not visually there in Music LibraryView attachment 15302
That's normal; your column width isn't wide enough to display the tag.
From what I can see in your screenshot, the "EXPLICIT" tag, which is longer than "Clean," doesn't have enough space to display.
Increasing the width should make the tag appear.
I have found what appears to be a waveform rendering issue in RadioBOSS 7.2.0 Beta.
In this version, the waveform display appears slightly shifted to the right compared to the actual audio position. As a result, the waveform does not visually align correctly with the real playback position and mix point.
To verify that this is not a Track Tool issue, I compared the exact same file and mix point in RadioBOSS 7.1.6.2 (stable version). In version 7.1.6.2, the waveform is displayed correctly and the mix start point aligns perfectly with the visible waveform. However, in the 7.2.0 beta, the waveform appears offset and visually suggests a short silence before the audio, even though no silence exists in the file.
The audio playback itself is correct — this appears to be strictly a visual waveform rendering problem in the beta version.
In Radio Boss 7.2 Beta, the volume cuts out when it reaches approximately 70%, and this also happens when I edit the fade settings in the track tool. The volume doesn't decrease gradually; it simply disappears.
As was said before, the playlists do not need to be timestamped, in some (most) cases it can simply be a single playlist file that's updated each time a new playlist is created. Overall, it's not complex as you describe. And, in any case, the generate command will be extended, as I told in the previous posts (this is also to prepare it for the new tool to manage playlist creation, as it would be easier to manage one event per preset, than two events per preset).
No, nothing was changed, at least not directly. Does it show any error messages?
I think this is due to audio buffering, the playback is delayed. Please ensure that "Prelisten" device in RadioBOSS's playback settings uses WASPI or ASIO driver, this is to reduce the latency.
