RadioBOSS 7.2 [beta]
Bug 1
When I completely collapse (close) the Top part of the window (the section with last track, now playing, next track, etc.) by dragging it with the mouse, and then disable the Tool bar in Layout, I can no longer expand the top window again.
It behaves as if the top section becomes locked and cannot be restored.
Bug 2
If I don’t touch the Tool bar itself, but instead disable all buttons and then enable them again, the Top window becomes empty, the content (last track, now playing, next track, etc.) disappears completely.
Even restarting RadioBOSS does not fix the issue, so at the moment I am left without that section.
That's only when you have the Scheduler tab visible, otherwise it will only be seen in the Status bar in the corner as [MAN] in the scheduler cell.
Yes, as you mentioned, it’s a bit inconvenient because when the Manuals window is open, it is only visible if the Scheduler tab is selected. Maybe you could move the (MAN) indicator to the left side to make it more noticeable, since on the right it tends to get lost next to the Silence and Scheduler indicators. I would even rename it to MANUAL so it’s immediately clear at first glance what it refers to.
I’ve been having problems because songs repeat too often when I use the Generate command and set a start time for a playlist. It is now repeating many songs that have already played recently, which is not correct because I have anti-repeat rules enabled. If I do not enable the start time option, it works correctly.
Here are two screenshots so you can see.
I set the start right now
