RadioBOSS 7.2 [beta]
Bug 1
When I completely collapse (close) the Top part of the window (the section with last track, now playing, next track, etc.) by dragging it with the mouse, and then disable the Tool bar in Layout, I can no longer expand the top window again.
It behaves as if the top section becomes locked and cannot be restored.
Bug 2
If I don’t touch the Tool bar itself, but instead disable all buttons and then enable them again, the Top window becomes empty, the content (last track, now playing, next track, etc.) disappears completely.
Even restarting RadioBOSS does not fix the issue, so at the moment I am left without that section.
That's only when you have the Scheduler tab visible, otherwise it will only be seen in the Status bar in the corner as [MAN] in the scheduler cell.
Yes, as you mentioned, it’s a bit inconvenient because when the Manuals window is open, it is only visible if the Scheduler tab is selected. Maybe you could move the (MAN) indicator to the left side to make it more noticeable, since on the right it tends to get lost next to the Silence and Scheduler indicators. I would even rename it to MANUAL so it’s immediately clear at first glance what it refers to.
I’ve been having problems because songs repeat too often when I use the Generate command and set a start time for a playlist. It is now repeating many songs that have already played recently, which is not correct because I have anti-repeat rules enabled. If I do not enable the start time option, it works correctly.
Here are two screenshots so you can see.
I set the start right now
RadioBOSS 7.2.0.7 beta
Changes
  • Render playlist to a file: fixed issues with voice tracks
  • Improved fading for voice track and file type beds
  • Fixed Mix Start processing when playing track was deleted (e.g., scheduled event with the "Replace playlist option")
  • Fixed track start time calculation after the playlist is replaced with a scheduled event
  • Fixed various UI bugs
  • Minor improvements
x86 https://dl.djsoft.net/beta/radioboss_setup_7.2.0.7.exe
x64 https://dl.djsoft.net/beta/radioboss_setup_7.2.0.7_x64.exe
It's the Status Bar and it actually does show the status of the scheduler, which is a standard UI practice :) Renaming it to MANUAL does sound like a good idea - and it'll be more prominent this way.
I think more information is needed to check this. How often are the playlists generated, and when they actually start (that is, how correct is "now" because if you start them like 2 hours later, it will break a lot of things). How long are the playlists. Check the log file (you can send it to us) - Settings, Open Settings Folder, open Log subfolder, the file is named playlistgenerator.log. Check if there are any errors and that the start time is actually correct.
Creo que se necesita más información para verificar esto. ¿Con qué frecuencia se generan las listas de reproducción y cuándo se inician realmente? (Es decir, ¿qué tan preciso es "ahora"? Porque si se inician dos horas después, causará muchos problemas). ¿Cuánto duran las listas de reproducción? Revise el archivo de registro (puede enviárnoslo): Configuración, Abrir carpeta Configuración, abrir subcarpeta Registro, el archivo se llama playlistgenerator.log. Verifique si hay algún error y que la hora de inicio sea correcta.
Se generan a los :59 de cada hora para que puedan cargar a los :00 de cada hora (1 minute after).
Esto se realiza las 24 horas del día, los 7 días de la semana, lo que significa que cada hora se genera una nueva lista de reproducción.
Sin embargo, hay un detalle importante: en el video se ve la fecha 29/03/2026, una semana después de que se generara esta lista de reproducción a las 19:50 de hoy, domingo 22/03/2026. Esto me lleva a concluir que las opciones "starttime: now" y "startday: now" no funcionan. Les mostraré el vídeo.
No hay errores por nuestra parte.
Yes, looks like a bug, it looks like it moves a week ahead for some reason. The next update will fix it.
What were the improvements, if I may ask? Can we fade out file type beds now and/or set their fade out parameters?
The beds were always faded out, based on the configuration, Settings > Playback > Voicetracks (for voice track beds) and Settings > General > Advanced (for MIC bed). Bed for the file type is faded out with the track itself.
What's changed is how the bed fading is implemented internally; there were several issues fixed with the Render Playlist to a File feature, as well as couple of minor bed-related bugs here and there.
Bug 1
Ok, the Top panel bug is fixed, but now it can’t be fully closed like before. Is this a bug or intentional?
It does seem that you should disable the queue mode while testing. From RadioBOSS perspective, it just does what it's instructed to do (delete played tracks, or not delete).
I'd just like to circle back to this as I forgot to reply. Yes, I agree, but I think the timing is wrong. I would assume the last track should clear from the playlist once it's stopped, not once the next track is played. Something you do to the following track (ie. play) should have no affect on a previous track.
It's like it's currently saying, "when track gets played, delete all tracks in the playlist marked as played". I would argue it should be "when in cue mode and track is stopped, clear from playlist as it has now been marked as played".
I'd even say that if a track is manually stopped, it shouldn't be affected by the queue mode, as it hasn't been fully played, it's been stopped. Maybe an option can be added for when a track is automatically played without any manual intervention (pause, stop), respect queue mode and delete from playlist, but if there has been manual intervention, do not respect queue mode and leave in the playlist.
We often have presenters who will stop a track in hopes to start it from the start again, but play another track, and then the original track disappears.
Sorry if this is confusing, happy to make another video if it's easier.
I don't think it can be changed at this point. Queue mode has a vast amount of minor things/corner cases that had to be taken into account, and presently it works as intended. Changing how it works would break a lot of things - this is a can of worms we'd avoid opening :) Also, deleting a track on stop is not an expected behavior for many users - a track is ready to be deleted once it's played (in full or not) and something else is started. It means that previous track is no longer needed, and (if queue mode is enabled) can be safely deleted.
It only deletes the previously played track, not the other played tracks that were played before.
This makes sense, I think an option can be added to control this. E.g., skip the queue mode on manual track switch. If this option is added, do you think this should be the default behavior?
Yes, that would be really good and should solve our issues! We personally would have it as default, but that might just be our situation, as our presenters do a lot of stopping/starting of tracks. Either way, even if it's not default, we'll turn it on ;)
OK, I'll see if this can be added in this beta.
I can't download the latest version. It says there's "Gen:Variant.Adware.Ursu.476".
This is certainly a false positive, I think you should let it ignore the "threat".
