RadioCaster: Incorrect mime type of ogg?
DJ Graco
Hi,
I recently needed to stream something in OGG on both Icecast and Opus. I noticed that the default RadioCaster settings are causing a problem, at least in the foobar2000 player, in both Opus and Ogg. The Firefox web browser also refused to play the stream. Regarding OGG, I've identified the likely cause, but I don't know what's wrong with Opus. Other streams in Opus, such as this one, play normally.
In OGG, the cause is likely the wrong default mime type. Instead of "application/ogg," it's "audio/ogg."
Opus requires further investigation.
Thanks in advance for any informations.
Best Regards
Graco
