PlaylistGeneratorPro command line switch behaviour
karlisma
What is wrong with the switch [ -s] here?
run PlaylistGeneratorPro.exe "-preset=NIGHT|MORNING|DAY" [B]-s=00|01|06 -n=1|5|1[/B]"-out=D:\PLAYLIST\night_%nn.m3u8|morning_%nn.m3u8|day_%nn.m3u8"
-n=1|5|1 works as intended [creates exact amount of playlists from each preset]
-s=00|01|06 does not work [every preset's playlist numbering restarts with 00]
so the result I now get is (wrong %nn values)
00_night.m3u8
00_morning.m3u8
01_morning.m3u8
02_morning.m3u8
03_morning.m3u8
04_morning.m3u8
00_day.m3u8
instead of (%nn values can be then loaded with ?hh mask)
00_night.m3u8
[B]01_[/B]morning.m3u8
[B]02_[/B]morning.m3u8
[B]03_[/B]morning.m3u8
[B]04_[/B]morning.m3u8
[B]05_[/B]morning.m3u8
[B]06_[/B]day.m3u8
actually would like to use much simplier file names
run PlaylistGeneratorPro.exe "-preset=NIGHT|MORNING|DAY" -s=00 -n=1|5|1"-out=D:\PLAYLIST\[B]playlist_%nn[/B].m3u8"
But that makes PlGen Error: 4 (preset and file name count mismatch)
The -s option doesn't support multiple parameters via |.
You can have different file name for presets by specifying multiple file names in the -out parameter e.g.:
"-out=D:\Playlists\Weekday%n.m3u8|Weekend%n.m3u8"
so, i found this previous conversation here
What do You mean with single command?
is it possible to get 24 playlists while:
1. keeping "no repeat rules" to whole generation process,​
2. keep file numbering right, so it is playlist_00.m3u8 to playlist_23.m3u8​
3. while using daypart presets?​
or... numbering will definately start from 00 on switching presets during process?
Is a commad line like this possible:
run PlaylistGeneratorPro.exe "-preset=NIGHT|MORNING|DAY|EVENING|NIGHT"-s=00 -n=5|4|8|4|3"-out=D:\PLAYLIST\playlist_%nn.m3u8"
