AutoIntro / voicetracks suddenly broken
ibek95
In the newest version all my previous settings for AutoIntro don't work anymore. After the intro it gets suddenly quieter before it gets louder ... what's happening here? Same goes for all voicetracks. Man, this update is again annoying - have to go back to 7.1.6.2. Please post the link for 7.1.6.2 for me, thanks.
Can you please be more specific, what is not working?
It doesn't seem to reproduce her, can you please provide more information at what moment it does become quieter, and for how long?
You can find previous versions in the customer area: https://www.djsoft.net/customer/
These are the settings that always worked:
The intro/voicetrack plays, after that start of song 1-2 seconds is too quiet before it goes up.
The fading settings here seem to be pretty high, I think you should lower the fading duration to make it fade in/out faster. Please also see Settings > General > Advanced configuration, in the Fading section there are options to control Fade In/Out of the Auto Intro tracks.
Hi Dmitry, sorry, these settings always worked without the issues I described. So it has to do something with this new version. Fading looks like this
This settings window if from the older version. It usually is not required to change the advanced settings, I advised in case you have changed those.
No, I didnt set it in the advanced settings, always in the general-settings (first 2 screenshots).
Does the new version 7.2 still have issues with this? A test does not confirm the problem. To confirm what volume is incorrect, of the voice track/auto intro track, or of the underlying music?
Unfortunately yes. I was talking about 7.2 all the time. It works fine with all older versions.
The Intro / voicetrack is playing correct but the beginning of the song is then suddenly quiet and gets within 2-3 seconds louder.
I'll add it to the list of bugs, if it's confirmed, will be fixed in the next update.
Unfortunately I must come back to this. I noticed that the voicetracks are fine when I add them new. But when older ones are played (that I set up before the RB-update to 7.2.x) the issue remains: suddenly there is a short fade-in of the song after the end of the voicetrack. But I never had problems with it before, never had this kind of fade-in, so it has something to do with the newest version I guess.
It shouldn't really matter when a voice track is added to the playlist (this information is not stored, and not checked) - what happens if you remove and add voice track again? The difference may be because the voice track or surrounding music tracks were edited with the Segue Editor.
Hmm, I never worked with the Segue Editor so I doubt that this is the problem here.
If I remove and add again with exact same settings then it works fine again. That's why it's so strange. :unsure:
