RadioBOSS 5.9 HTTP API compatibility
Radio-Albena
Hi Dmitry,
Were the HTTP API commands for reading current playback information and inserting an audio file into the playlist already available in RadioBOSS 5.9?
Have their commands, parameters or response formats changed between 5.9 and the current version?
Also, is an official 5.9 installer still available for compatibility testing? The old download link no longer works.
Thanks!
Raymond
Some commands were available, but their results will likely differ significantly (newer versions return much more data).
I don't think there were any incompatible changes, so if you need older scripts to work, they will likely continue working with the latest version.
You can find it in the Customer Area in the older versions download page.
Hi Dmitry,
Thanks for your reply!
I've checked the Customer Area and the older versions download page, but unfortunately I cannot find RadioBOSS 5.9 there.
Could you please check whether version 5.9 is still available and provide a working download link?
I need it to test compatibility with BroadcastVoice, as a potential customer is still using RadioBOSS 5.9.
Thanks again!
Raymond
