Ad Scheduler Remote Operation
What is your recommended setup for adding the adverts to the main RB onair playback machine from a remote PC - does the audio get transferred from the latter or should the audio be stored on the former, or should the advert be stored on both machines (i.e. what is the reason for the "export audio files" being ticked?)
Should the advert working file be restricted to the one on the on air machine?
Thanks. So where does the transferred audio get saved on the RB machine?
It's saved to a temporary folder inside RadioBOSS settings folder. You can make an export, and open one of the ads playlists to see the exact location.
