Correction VST and winamp plugins
nelson c
Hi Dmitry, I have found that when RB was this stop loading or streaming buffer, disable VST and winamp plugins.
This causes me a problem;
Stereo Tool I use VST sound processing, and generate Stereo & RDS.
Then when I play streaming and loading the buffer off tool and Stereo receivers not turn on the stereo and neither LED will read the rds, I mean it's almost as if my radio is cut.
There's not obvious workaround for this: in the Settings->Microphone/Line.in chech the "Disable Local Echo" option. Besides disabling the echo, this option also makes program to produce continuous audio stream.
Let me know if it works or not...
I have a question. anyone knows a VST capable of chaining several VST? If possible free.
I want to:
RadioBOSS --- >> IZotope VST --- >> VST Stereo Tool
thanks
Recent finds a bug in the VST, uncheck the checkbox when the vst vst although disappear from the list, if any execution continues in operation.
Confirmed. Thanks for reporting!
in the latest versions this was no longer so, and now while loading buffer, stereo tool is stopped, so that the LEDs do not light rds stereo and in my station, while charging the buffer.
thanks
Yes this was changed so Disable Local Echo option would just disable echo for mic and doesn't do anything else.
Instead a new option will be added "Produce silent output while nothing is playing".
The reason is: making things more obvious and easier to understand.
