NICKY G DJ
I would have a series of doubts if someone can help me:
1. I cut and prepared a perfect LOOP file, saved in * .ogg so as to keep the cut clean and precise, I imported it into a well cart and looped. the result? bad it feels the net detachment when the loop starts again. how can I solve if you can ??
2. How can I manage daily directories generated by downloaded files with automatic download? or rather I explain myself ... I would like to create the horoscope, the weather, the news ...
3. I was not able to make the request of the songs work through the website, could someone help me?
4. Is it possible to convert a database from MBSTUDIO?
thanks <3
- a) download everything OK ... for the horoscope I have 12 files with the same name that will be downloaded automatically ...
- b) how should I create the sequence ?? how can I make a mini list where I put a signature, horoscope 1, horoscope 2, horoscope 3 ... final signature ... ??
sequencing the horoscope files you hear the detachment and the attack is not very fluid ... (if I mount them with adobe audition removing the small empty spaces, you feel great) ... - c) is it possible to put a background base in loop and to overlap the parts of the voice tracks in sequence above and the loop stops playing at the end of the last voice track?
- d) downloading files for NEWS automatically, then every day the files will have different lengths, can I decide at random that the file always sounds by cutting 10 seconds at the beginning of the file and 10 seconds at the end?
thanks <3
