Problem installing the software on windows 7 32bit PC
omoyetips
Hello there,
My name is Awesome Junior, I have an issue with the radio boss software.
I have downloaded the radio boss software to my PC. When I try to install the software, it then stop's my PC from running. How do I go around this?
Hello there,
Have you tried to install the 64 bit version on a 32 bit operating system ? maybe this is the reason
RadioBOSS runs in a user mode, so it technically can't stop your computer from running. Something else is wrong, but it's not RadioBOSS.
I doubt it will install at all (did not check). But even if it's installed somehow, it will simply not run and show an error message like "Invalid executable"; it will not crash or "stop" the computer.
