Radiologger problem
Radiologger 2.2.0.37 Work like a weel very good on xp3 no problem ,i have a little request on it when recording  live assist the show meter works i can see the level of my rec but on playing same file on Radiologger during playback the level meter dont work can u fix it .
in radioboss i have strange problem i set prebuffer to set minimum buffer size automaticly during playback i have some gargle in audio t2 t2 t2 t2 i want the best setings for buffer i have p4 512 ram a bit old machine .
Is there any application little utilities than can determine automaticly the best buffer size for a software ex:RadioBoss
thanks .
The level meter for playback is added to wish-list, and will be added in the next update of RadioLogger. Don't know when, maybe after 1-2 months. Not earlier.
If you have an old machine, there is the only way to get minimum latency: you have to buy a sound card which has ASIO capability and use ASIO input/output in RadioBOSS.
You processor's power is not enough to keep small buffer always full, that's why sound is corrupted (the smaller the buffer size, the more frequently it is needed to be updated, which causes high CPU load).
