P
Could you please give more details on what happens?pety said:I detected a RB ANOMALY (and I captured it).
It is a strange behavior. Is it possible to be that the cause of the crash?
It happeneds very frequently (interval by one minute.)
The behaviour is in images.
Maybe you started program several times? There should be 1 guard for each instance of RadioBOSS.pety said:Why two radioboss_guard.exe ?
RB acts like beta product.
djsoft said:Could you please give more details on what happens?pety said:I detected a RB ANOMALY (and I captured it).
There should still be only one guard after restart.pety said:RB crashed today at 19:08 and it restarted becouse I have respected your recomandation: I checked "Restart the program..." Maybe that's why there are twu rb guards on.
The first bad behavior was displaying from time to time that logo "radioboss - loading, please wait.." It did it until morning, when I stopped RBdjsoft said:There should still be only one guard after restart.pety said:RB crashed today at 19:08 and it restarted becouse I have respected your recomandation: I checked "Restart the program..." Maybe that's why there are twu rb guards on.
Is the secong guard doing somethign wrong, or it just sits in the process list?
Probably it's the second radioboss_guard trying to start RadioBOSS, but because it's already running (and you have an option "Prevent multiple instances" turned on) - new instance just displays logo and closes.pety said:The first bad behavior was displaying from time to time that logo "radioboss - loading, please wait.." It did it until morning, when I stopped RBdjsoft said:There should still be only one guard after restart.pety said:RB crashed today at 19:08 and it restarted becouse I have respected your recomandation: I checked "Restart the program..." Maybe that's why there are twu rb guards on.
Now it is OK..only one instance and works rightdjsoft said:Probably it's the second radioboss_guard trying to start RadioBOSS, but because it's already running (and you have an option "Prevent multiple instances" turned on) - new instance just displays logo and closes.pety said:The first bad behavior was displaying from time to time that logo "radioboss - loading, please wait.." It did it until morning, when I stopped RBdjsoft said:There should still be only one guard after restart.pety said:RB crashed today at 19:08 and it restarted becouse I have respected your recomandation: I checked "Restart the program..." Maybe that's why there are twu rb guards on.
Thanks for your work!djsoft said:Currently working on those problems, I think it will be resolved soon.
Sorry for the inconvenience...
