Hello, is it possible to disable selected icons from the tools panel or somehow delete them in the program files.
Sorry for my english because it's google translate.
Regards and thank you for your help.
Even if those icons are removed, the toolbar will still stay and occupy exactly the same amount of space. As an alternative, you can hide it completely from the View menu.
Hello, I know you can, but I do not mean the height of the buttocks by the width, after removing these icons I will fit all the jingles I have 17 inches on my laptop and finally it moves in the air.
Hello, my point is that if the Radioboss will give you half the screen and there are 10 jingles, then you cannot see the entire tool panel and I want you to see that I am connected to the server.
