DTMF Checker
DTMF Checker
A utility to detect DTMF tones in files.
(last updated: 5/1/2024)
SHA256: 8f97de16bbe0dfec7084604a70a29e5f0132ba1003a5192a554ed0aba2f4366f
How to use
Press the "Open..." button and select a file (mp3, wav, ogg). The file will be processed, and you will be able to see the detected DTMF tones in the field below.
Hi,
  I am using DTMF since it has been released and I am planning using it even more intensively.
I would like to have more information in order to get a reliable detection and to try to hide from listeners the DTMF tones has much as possible.
I notice that during normal playback DTMF digits are regularly detected in the music, I also notice that occasionally the DTMF code is not detected by RB hense the associated task not started.
Could you please publish some best practice?
Here are a few questions I can think of.
What is the recommended number of digits to use?
Is it necessary to have a blank before the first digit, after the last one and between two digits?
What are the recommended digit duration and the ratio with blanks between digits?  ie 40ms digits separated by 20ms blank.
Is detection only on left channel?
What is the recommended audio level for digit? What is the signal ratio between digits and background music? And what is the recommended value for the RB DTMF level detection setting?
Could the DTFM checker and the RB debug info window display some king of quality detection when detecting DTMF?
Regards
Christian
Christian, currently there are no best-practice settings I can post...
The interval between digits should be about 45ms, the tone durartion should be at least 50 ms - this is for reliable detection. You can try varying those lengths to see how it works. In most cases stations use 4 digits.
The level depends on the signal level... The lower you set it - the more false-detected tones (eg. from the music) there will be. This value should be set experimentally.
RB can't display quality, it either detects a tone or not... The quality measurement here is how many false detections you get.
I am new to this feature, I've read about it, I just dont know how to send the tone to RadioBoss, can i use my mobile? or i have to make online broadcast radio to send it ?
RB can check the tone on sound card's input or from network stream. If you want to simply control it remotely, you better to use the API: http://manual.djsoft.net/radioboss/en/remote_controlapi.htm
so I have to play the tone from my computer to get the event to run, I dont get it how could this be useful ? I read the manual, didnt get it though, if there is more information.
I read the manual and the commands, but how to apply them ? assume I am home now, how can I send these commands to my work's RadioBoss ?
Usually DTMF is used when you rebroadcast another station and insert your own (e.g. local) ads. It's not intended for remote control.
All the commands are sent using HTTP requests. You can use web browser, just put the request in the address bar. There are examples in the documentation, try them.
got it, worked fine in our local network. thanks ,
would it work with the global IP or it's just for local IP ?
If you have an external static IP, it will work with it as well.
DTMF checker updated.
What's new:
- Different DTMF detection modes: Left, Right, Left+Right, Counterphase
- Faster file processing
I have downloaded dtmf checker and its showing a virus in the dtmf checker file-
Filename: dtmfchecker.exe
Threat name: WS.Reputation.1Full Path: c:\new folder\dtmf\dtmfchecker.exe
On computers as of
28/12/2016 at 6:27:48 PM
Last Used
28/12/2016 at 6:29:48 PM
Startup Item
No
Launched
No
Threat type: Insight Network Threat. There are many indications that this file is untrustworthy and therefore not safe
____________________________
dtmfchecker.exe Threat name: WS.Reputation.1
Locate
Few Users
Fewer than 50 users in the Norton Community have used this file.
Mature
This file was released 5 months ago.
Medium
This file risk is medium.
Source: External Media
Source File:
dtmfchecker.exe
File Actions
File: c:\new folder\dtmf\ dtmfchecker.exe Removed
File Thumbprint - SHA:
0485550536f4b76eaeb6947e4ebae3cc84852452f5628315a651d8eb04e43ec2
File Thumbprint - MD5:
Not available
This is not a virus, it's some sort of "Reputation", I'm not sure on what it's based on - you should ignore this message.
Still no voice trakbed?
I thought you said in a previous post that in this version you will add playlist pause and music voice bed while mic is open
Does it concern DTMF Checker utility?
DTMF Checker
How to use
If it detects the tones correctly but the radioboss does not execute them, test the input and see when the audio of the tones is played and received. It actually seems strange to me.
If the tones are detected in the DTMF Checker but not in RadioBOSS you need to ensure that the DTMF source is properly configured, and also the scheduled events - they need to check for DTMF tones at the right time.
