RadioBOSS 6.0 [beta]
RadioBOSS 6.0.0.2 beta
Changes
  • Preload also pre-scans track to trim silence and detect mix point
  • Fixed slow switch to the next track when a track is skipped
  • Fixed incorrect song duration in Report Generator
  • Disabled scheduled events are moved to the bottom while sorting
  • Fixed: file types list did not work properly in Music Library
  • Fixed errors when using MySQL database
  • Activated getencoder, setencoder, deleteencoder API commands
  • encoderstatus API command result also includes stream name
  • Fixed: drop files from Windows folders to Music Library did not work
  • Fixed next/prev buttons did not work in Track Tool when used from Music Library
  • List of music libraries is now sorted alphabetically
  • Fixed crash on startup with "Start minimized" option
  • Improved sweepers duration calculation
  • Minor improvements and bugs fixed
Download: http://dl.djsoft.net/beta/radioboss_beta_6.0.0.2.exe
Sugerencia para futuras actualizaciones: Sería excelente poder generar de manera automática una Copia de Seguridad del Sistema para evitar perder información ante un cierre inesperado del R. Esto podría hacerse en un horario fijado por cada usuario.
Otra sugerencia. El programador de Publicidad no guarda la última versión que usamos. Cuando se cierra rara vez vuelve a la última versión y hay que cargar todo nuevamente. Si existe y no lo estoy usando agradezco su ayuda.
the same error as before
here the log file
En la función Buscar en la lista Principal no se remarca o resalta la búsqueda como lo hacía en versiones anteriores.
I have a suggestion for the Start Time column in the player.
Would it be possible to have the Start Time be live when not playing.
I use this to insert ads, weather, news at specific times, and I create the play list before I go to air.
I would like the Start Time to be live all the time, not just when playing.
On the line that displays "Last Track" "On Air" and "Coming up next" would it be possible to show the sound wave for the track, same as in the Track Tool?
Θα χρειαστεί πολύς χρόνος για να ορίσετε τη θέση με αυτόν τον τρόπο. Πώς είναι αυτό χρήσιμο για ροή ραδιοφώνου; Η αναζήτηση θέσης δεν είναι ένα τυπικό χαρακτηριστικό.
Είναι ένα πολύ σημαντικό στοιχείο για έναν χρήστη που χρησιμοποιεί ένα πρόγραμμα ανάγνωσης οθόνης και χρησιμοποιεί αυτό το πρόγραμμα για να παίζει μουσική στα καταστήματα. γιατί γνωρίζουμε ότι τα περισσότερα προγράμματα δεν επιτρέπουν σε έναν τυφλό χρήστη να τα χειριστεί. επειδή το πρόγραμμά σας είναι το καλύτερο για εμάς θα ήταν ένα πολύ καλό και ενδιαφέρον χαρακτηριστικό να το προσθέσετε αμέσως. και πραγματικά τώρα εκφράζω τη γνώμη πολλών ανθρώπων που εργάζονται σε καταστήματα και χρησιμοποιούν το δικό σας πρόγραμμα.
like this you have realtime
This is already possible using the createbackup scheduler command: https://manual.djsoft.net/radioboss/en/scheduler_commands.htm
Ads Scheduler saves all the configuration automatically, and if you close it and open again, everything you have configured will be present.
here the log file
Yes, sorry for that, it seems MySQL needs another fix :)
It marks the found track with a selection.
This is possible, right-click a track from which you need to start the calculation, and select the "Calculate start time" option.
Cuando se mueve o arrastra un pista dentro de lista principal se desordenan otras que ya estaban programadas en un orden especifico.
Can you please provide more information about this issue?
But I'm thinking if can add a search on this area
That will help a lot
Can you please specify where the search should be added?
It can display the waveform for the currently playing track (On Air) only, to enable it, click middle mouse button on the green bar, or use Settings->View to change it to Waveform.
What the hack is Music Library doing?
It seems that you have added the whole C: drive to it, or the entire "My computer" section.
Add Folder in Music Library doesn't work
Music Library is destroyed
What folder did you add? A quick check does not confirm the problem. Please note that it adds both checked folders (with checkmarks next to it) and also the folder that is selected.
¿Puede proporcionar más información sobre este problema?
Le doy mas información como se desordena la lista cuando arrastramos una pista. En este caso moví la pista remarcada en azul en la lista hacia arriba.
Esto ya es posible usando el comando del programador createbackup : https://manual.djsoft.net/radioboss/en/scheduler_commands.htm
Okey, lo he descubierto. Muchas gracias.
Ads Scheduler guarda toda la configuración de forma automática, y si lo cierras y vuelves a abrir, todo lo que ha estado presente estará presente.
En mi caso cada vez que se cierra nunca vuelve a la versión configurada por última vez. Algo mal debo estar haciendo
Marca la pista encontrada con una selección.
Y eso cómo sería. No encuentro esa opción
