RadioBOSS 6.0 [beta]
The point is that ML scans the entire system when I checkd only Bluess folder. It is on partition E:\
I don't seem to be able to confirm this. Can you please make a screenshot of the folder selection dialog just before you click OK?
¿Quiere decir que la pista se duplicó mientras la arrastraba?
Necesita crear un evento con estos comandos y hacer que se ejecute periódicamente.
La Pista no se duplicó, al moverla hacia arriba desordenó lo que ya estaba ordenado cambiando de posición todas las pistas.
En la función Buscar en la lista Principal no se remarca o resalta la búsqueda como lo hacía en versiones anteriores.
Marca la pista encontrada con una selección.
Cómo se realiza esta selección sugerida para resaltar la búsqueda?
if I want to prelisten a song in the playlist and mute playlist, also the streamoutput is muted
I have exactly the same settings for the output as in the 5.9 version
In 5.9 only the playlist was muted it did nott affect the stream
Thankd for the details. Please wait for the next update, it will have some dragging-related problems fixed.
I'm not sure I understand. The found track is selected in the playlist, it also scrolls the list to make it visible. It doesn't work like this in your case?
It shouldn't mix the stream, seems like a bug - thank you for informing about it.
Yes, I hope it can be solved soon. Our main PC is affected by this bug
It will work with the current version if you use MariaDB 10.4 or newer. The error only occurs with older database ebgine version. The next RadioBOSS version will correctly work with older versions (10.2 and 10.3).
Upgrade to version MariaDB 10.5 and a BackUp of the old DB doesn't work. (Only if I set the "version" table to 9, but it doesn't find the tracks)
After finishing the current track, the panels are not updated. (Using the stop option)
Should our forum not be English Language only ? This is the norm for forums.
When Dmitry answers a a question in English that was asked in non-English, it makes it hard to know what he is responding to. The trouble is, the question could be very relevant to me as well, but I wouldn't know.
I'm amazed at the number of people installing a Beta on their main system and then moaning when it doesn't work, and then expecting instant repairs. Go away you people please !!
Why would you do that when Dimtry said explicitly not to load it yet on existing systems until all bugs are solved ? You are just asking for trouble doing silly things like that.
Se podria agregar al igual que RADIOCASTER, en METADATOS de RB la opción de leer desde archivo el nombre de la pista?
I feel like that also
My foreign languedge is dutch ( Belgium ) i live in Germany, never learned english in school, but i do my best to write englisch here
Patrick
It seems that your database in not in consistent state, if you manually edited version and restored backups. Try settings the version to 6 or if you have a backup from RB 5.9, restore it.
If you used 10.4 at the time of installing 6.0, it should have worked with no error. We tested upgrading from RB 5.8 and 5.9 database and no problems found.
Thank you, seems like a bug.
Yes, this is a happening I don't really know how to handle properly. Spanish speaking people provide great and valuable input here. I have made numerous attempts in asking to write in English but as you can see it's not really working :) I'm not sure maybe create a Spanish forum section, like there is already separate Russian forum.
Using beta in production used to work well enough for previous betas, so it's sort of OK to also install this one in production. This beta is different because lots of internals were rewritten, introducing more bugs.
RadioBOSS only uses its own metadata, if you need such a feature, I suppose RadioCaster is a better tool for this task.
I also want to ask you to write in English so all forum users cvan understand and benefit from the conversation.
Is it possible to use the button for the stream to have a dropdown menu where you can choose the encoder you want?
Maybe with a sign that you can see which encoder is connected.
Currently the "Broadcast" button connects to all enabled encoders, you can enable/disable them in Settings->Broadcasting.
RadioBOSS 6.0.0.3 beta
Changes
  • Fixed: looking for DTMF signals in network stream did not work
  • Fixed: Mute playlist in Prelisten window also muted playback in stream
  • Fixed: "One track only" for "Stop after this track" did not work
  • Fixed: search by tags in Music Libarary and Search tab
  • Fixed several errors with drag-n-drop inside and between playlists
  • Fixed playlist sorting bug
  • Added search in all music libraries
  • Added "Save selected as playlist" menu command to music library
  • Legacy XML music libraries can be loaded in Playlist Generator and imported in Music Library
  • Fixed several issues with MySQL database
  • Minor issues fixed
Download: http://dl.djsoft.net/beta/radioboss_beta_6.0.0.3.exe
Now after installing the 6.0.0.3 the stream is ok, but checking mute the playlist is muting everithing also the file that i am prelistening
The Streamsignal is OK now
All the same settings as in 5.9 (see the picture), there i could prelisten and mute only the playlist
No, I don't think creating a separate Spanish Section is the answer as the questions being asked would be just as lost to the English forum, just as they are now being lost because we don't know what the question being asked is.
There is just such a lot of Spanish questions being asked, that I am quite sure that as you say "they provide great and valuable input" so from my point of view I would love to be able to see them.
However this is a suggestion, but bear in mind I am not wishing to create an extra burden of work for you.
I presume you have to translate a Spanish question to English... to answer it... so that perhaps you could place the English translation right underneath the Spanish.
I think this is the answer, provided it doesn't create too much added workload for you.
What's new
  • Crossfading improved to be more smooth and precise
  • Next track is preloaded allowing for instant network stream start and speed up local track startup
  • Added separate fading duration options for Stop and Next Track
  • File type option added: skip after set file types
  • Playlist Shuffle playback mode improved: now it tries to select tracks that did not play recently
  • Comments can be added to the playlist (a comment looks like a track but can't be played)
  • Last played history for a track, can be viewed in track information panel (hover the "Last played" text) and in Music Library
  • Added filters for log window: show all entries, errors only, or scheduler related events
  • Added Search for scheduled events (Ctrl+F) to search events by action or name
  • New UI themes: Light, Flat, Dark (access them via Settings window View-Style section)
  • AUX and Overlay players are now fully featured players supporting crossfading and other features
  • Improvements in Search in the main window: faster search and load; added search by artist+title and intro
  • More columns added to the playlist window
  • Auto Intro: added "Skip after selected file types" option to prevent auto intro being inserted after certain file types
  • Added module icons to the toolbar (Ads Scheduler, Playlist Generator etc)
  • Settings backup command ("createbackup") also creates database backup (only if SQLite database is used)
  • Ability to create and restore database backup from the menu (Settings->Backup and Restore)
  • Teasers: added "Include subfolders" option to also read tracks from the subfolders
  • Added "0" button for quick access jingles
  • Added "Delete profile" command
  • Added "Copy to" playlist right-click menu option to copy a track to another playlist
  • Improved relay to playlist and back transition smoothness
  • Added API commands to control encoders (add, edit, delete encoders)
  • Added Korean translation
  • Improved high-DPI/4K monitor support
  • Manual operation: "stop after this track" button can synchronize its state with Manual scheduler option
  • User defined fields can be used in title format (%user1, ... %user5)
  • Microphone: ability to force downmix microphone sound to mono to account for cases when microphone is only heard in left channel
  • Network stream URL no longer revealed when HTTP notifications are used
  • SQLite database is now used as default storage for additional track information instead of APEv2 tag in the previous versions
  • Added user agent configuration for network stream playback
  • XML nowplaying file also includes the previous track; does not include tracks with the "Do not send title" option enabled
  • Lots of minor user interface improvements in all areas
Track Tool
  • Playback parameters (mix point, fade out, track end, level) are applied immediately to the currently playing track
  • Added track format information (sample rate, channels, bitrate)
  • Zooming does not require Ctrl to be pressed
Playlist Generator
  • Added UI themes support
  • Minor improvements
  • Fixed repeat protection when using the "Consider tracks in the playlsit window" option
Music Library
  • The Music Library has been reworked. Now it uses a database management system for information storage (instead of XML files in the previous versions). Improved search, load, and sorting speeds. More data fields are displayed in the list (columns can be selected). Drag-n-drop files from the library to Windows folders. Lots of other improvements.
  • Disabled tracks are marked in the list with color (grey background)
  • Tracks with missing or empty tag are marked with italic font in the list
Segue Editor
  • Changes are applied immediately to the playing track
  • Minor improvements and fixed bugs
Report Generator
  • Fixed: some tracks were included in the report ignoring the "Do not include in the report" file type option
Fixed
  • Fixed: some hot keys did not work in additional work zone
  • %nextsong variable included track title even if title was disabled in the settings
  • File type for line in sometimes did not work
  • Multiple playlist create UI bug fixed
  • Fixed occasional AUX playlist resize bug
  • Fixed: scheduled events sometimes were not inserted into the proper position into the playlist
  • Fixed: incorrect track mixing position under certain circumstances
  • Disable installing an automatic update for users with limited rights
  • Fixed several bugs with "Trigger mix at" feature
  • Fixed Teaser end fade/mix did not work right sometimes
  • Fixed: broadcasting statistics "froze" sometimes
  • Time announcement with "treat as voice track" option was sometimes processed incorrectly
  • Fixed: scheduled events occasionally could have same IDs
Changes incompatible with the previous versions
  • Minimum required version is Windows 7; Windows XP is no longer supported
  • Removed "Skip two or more tracks" file type option (use "Skip after file types" instead)
  • Removed legacy Playlist Generator
  • Music libraries created in previous versions will not open in this version
  • Removed "playfile" and "read_folder" scheduler commands
  • "makelibrary" scheduler command does not support full paths for library names (because libraries are no longer saved to files), only the library name must be specified
License key:
The free key expires January 15, 2021.
RadioBOSS 6.0 beta: http://dl.djsoft.net/beta/radioboss_beta_6.0.0.3.exe (10/4/2020, 35Mb)
Just downloaded version 6.0.0.3 but it comes out as 6.0.0.2
