Bugs report (radioboss 6.2.2)
JeanXeb
Hi radioboss,
- Commands in studio are seen as a file read error. (screen 1)
Unable to play! Error code 2 (unable to open the file/invalid server address).
- In the discotheque the classification by alphabetical order of titles, albums, date Added ... does not work.
(When you click at the top of the column) (screen 2)
- In the MySQL database, the old files remain registered in the database and are not updated. (trackinfo and tracks2)
- Last remark, the "createbackup" command programmed in the scheduler freezes the studio and restarts it.
Thank you for your attention and your responsiveness !
Cordially
It means the file does not exists at the location.
Screenshot 2 does not include the Date Added field. Did you mean sorting by title?
Yes, they are not deleted - in case you add them again. You can cleanup the database using the command in the Tools menu in Music Library.
Does it always happen or only sometimes?
Also please specify what RadioBOSS version do you use.
Hi Dmitry,
Thank you for considering these comments.
It is normal that it cannot find a file because it is a command... (command add in the playlistgenerator)
Sorting by alphabet in the library does not work for : Title, album, date added.
The version is radioboss 6.2.2.0
Cordially
Yes the commands are working properly in the generatorplaylist and in the studio.
But since it is a command no sound the studio send the error :
The module : "Option d'attente" seems not to work
(there is no DTMF trigger)
The error is not about the "stop" command, it's about the "LINER" file.
It's actually a command.
It's a parade to allow radioboss to select the right liner (sweeper - autointro) at the right time...
This is a command to control the autointro in order to remind the listener of the time slot he is listening to. I haven't found any other solution.
For example in the morning good morning listening to our station etc.
In this case, either use a real file - you can create a 0.1 second file for this purpose, this will get rid of an error message, or you can probably use Track List instead: https://manual.djsoft.net/radioboss/en/using_track_list.htm
