If you restore backup from another user, some absolute paths will include the old Windows user name, under which backup was created. It's easy to fix, for the error box you shown - open Settings in Ads Scheduler and edit the working folder to point to valid user.3) Goto the opened beta and choose scheduler and press 'on' the checkbox.
4) From the Menu : Tools>> Ads Schedular . On the dialog press 'Create Playlist and Events' button this error will appear :
I'll see if we can get rid of absolute paths in those places to make it easier restoring backups.
It's in Playlist->Extra->Sweeper repeat protection menu.You should also note the 'Sweeper track repeat' is missing from this beta it used to live on the View Menu
Time will show, we plan on releasing RadioBOSS 6.4 beta in October.Can you confirm that due to the lack of an 'auto intro' route and 'inset wav' separate to the main music field we will be unable to use radioboss with a dsp and use these announcements until next year?
