New Graphics for the Intro and Outro Bar
matteolop
Hi, I would like to see a New Graphic for the Intro and Outro Bar. :giggle: (y)
maybe the same color as the "Intro" and "Outro" mark.
and that the progress bar is bigger and longer, and maybe the same color.
another thing: the timer that flashes red, when there are 30/15/5 seconds left until the end of the track on the air.
A new view for displaying "AutoIntro" and "VoiceTrack" when running.
What do you think?
can this be done in the future?
A thousand thanks
You can resize current/next/previous track bars by dragging space between them.
As for visual changes, do you have an image to visualize it? We can add more color parameters, but redesigning it completely is not planned at this moment.
definitely too small, I would eliminate the application bar and make room for the intro bar
It would be nice to see a simple countdown with the uppercase font flashing green (same as the intro mark) that lights up in the same position as the current bar.
Same for OUTRO and the "AutoIntro" timer
How it's different from how it is now, only make the font larger?
When the intro starts the countdown number appears and a green/blue bar, this bar is not needed, just make the countdown number appear in a larger size.
Ps: let's hope that this translation is as faithful as possible because this is another problem that I find, I write one thing in Italian but then the Google translator means another.
I think a lot of people want to actually see the bar moving, not just the numbers. IIRC the bar was added because it was requested.
