New Graphics for the Intro and Outro Bar
When the intro starts the countdown number appears and a green/blue bar, this bar is not needed, just make the countdown number appear in a larger size.
This beat, at least for us, is very necessary, we work with the intro and outro of the songs. And it is easier for announcers to be guided by the bar than by the countdown.
I also agree with the larger font and leaving the slash.
It would also be nice to change the Waveform Audio view similar to this.
with much more visible mark points and better graphics
Thank you
Yes, I know, I also intend to add the writings (as you see in the photo).
I'm not sure what the point would be. The Nowplaying window is small, that's why there's no unnecessary text, to avoid it being cluttered. It's all marked in color anyway.
Hi, ok I understand.
Maybe it would be nice to be able to widen the height of the playback window? what do you think?
You can resize nowplaying/last played/next track areas using a mouse.
Perhaps it is better to enlarge or redesign this area, since it is the most important one for the live speaker.
The playlist area takes up almost all the space on the monitor... I don't know if you know what I mean. Thank you
The next version will have more options, including the intro area font size, and also Scale that will allow scaling the entire UI - also making the Nowplaying area larger.
Also, thinking about it - there also an option in the View->Top Panel menu that offers Full/Minimum/Hide options, I guess we can also add the "Large" option there to increase further increase the top panels size.
Hi, I agree with putting the "large" option.
And why should you even "Hide" the "Nowplaying" area instead?
I would rather leave only three options for radios:
  1. Small
  2. Medium (Default)
  3. Large
  4. Custom (optional)
furthermore, for the more technical people in the sector, close to the VU meeter,
it would be nice to see the dB and/or LUFS Audio level in real time.
or place it at the bottom in this area, positioned horizontally (see photo)
Thank you
Some people want to hide it, maybe to save screen space or when it's used as a simple player. About the VU meter, maybe we'll do something in future versions, but for RadioBOSS 7.1 the list of improvements is already fixed.
Hi, ok very good.
If I buy RadioBOSS by the end of the year will I have included version 7.1 and later?
How many updates do you make in 12 months of license?
Allow the possibility to enlarge the font of the intro/outro countdown, in my opinion it is too small and difficult to read.
If large is the beta version, it's still too small, if anyone has ever seen the mb one they know what I mean by visible countdown
Se large è quello della versione beta, è comunque troppo piccolo, se qualcuno ha mai visto quello di mb sa cosa intendo per conto alla rovescia visibile
It's made larger in the latest 7.1 beta, please check.
It's already a very big font + countdown bar. Making it larger will make things look ugly and unbalanced.
