Intos on new Beta version.
shire
I downloaded the Beta version to see what was new in this version and when i added my songs in there was no intros at all.
So if i was to buy a new version would i have to redo them all again?
Your current database must be backed up. Then, restore it to the beta version to retrieve your intros and other information added/modified on RadioBOSS regarding tracks.
Note: the file paths (tracks, jingles, etc.) must be identical. Otherwise, it won't work.
Backing up and restoring settings can also be done to retrieve other settings and information.
When you install beta version it's the same as if you have installed an update, so it will keep all the settings and file parameters. Looks like you have installed it to a different folder, so it started as a fresh installation. And additional information storage differs from the version you had installed before - that's why Intros and other info was not loaded.
Please see this for the details: https://manual.djsoft.net/radioboss/en/additional-information-storage.htm
To fix it, please open your previous installation and check what option is selected in Settings > General > Additional information storage location.
Then select the same option for the beta installation.
If beta version is installed on top of the regular one, no backup is needed. Also, if "Additional information storage" is the same then all track info will be shared among different installations.
I'm installing RB into a new computer, will all I need do is run the installer program and copy the RB folder over to the new machine? Anything I'm forgetting?
I suggest performing a full installation on a new computer, not copy the RadioBOSS folder. If you want to move the configuration, use the Settings > Settings backup/restore command.
