Cleaner file explorer
Wheslley
It would be nice if you can choose the path of the folder tree to be displayed in the file explorer, so you can not list unnecessary folders, leaving a cleaner look and making it easier to browse a particular file or folder. as you can see in the second image.
In this example of the second image the user indicates which folder will be displayed, and inside this folder will have other folders with files that the user uses most frequently.
