Compatible Traffic and Billing software
madbeatz
We have been using a manual system of logging adverts and spots for a number of years and now with growth looking to automate a lot of the process around advertising. Is anyone here using a Traffic and Billing software which works well with RadioBoss?
  1. Was the integration easy to setup and configure?
  2. What is your experience?
  3. What is the learning curve like?
Appreciate the help.
madbeatz
Thanks, I have been using the ads schedular for the last couleof years and its great, but really need to move towards automating billing and invoicing, campaign management etc.
If there's any particular feature that's missing, we will consider adding it.
As for integrations, RadioBOSS uses standard m3u/m3u8 playlists - this should be supported by any software (it will also read m3u file if it's simply a list of file names). Scheduled events are also stored as text or you can prepare events in advance and then only make the other software to update the playlists.
