J jopara Member Mar 4, 2017 #1 Hi. I am doing some tests with dtmf tones and I would like to know if you can create tones through a command. Thank you
D djsoft Well-known member Staff member Mar 5, 2017 #2 Yes, you can generate DTMF tones in RadioBOSS, in the menu click Playlist->Extra->Add DTMF tone generator. If you want to generate tones using the scheduled event, enter DTMF=abcd" (abcd - sequence you want it to generate).
