Normalise tracks based on decibel level, not just loudness
Actually, it might be worth having the advanced feature change the labels. In track tool etc. it still says LUFS, even though when the option is ticked, it should now be DB or something similar?
When you normalize using the EBUR algorithm, it will use LUFS as target units, -9 LUFS is roughly 0dB. In the advanced section, you can enable the additional option to prevent going over 0dB (Settings, General, Advanced configuration). There you can also switch to using the Peak normalization algorithm. In this case, units are decibels (while UI still shows LUFS, it's actually dB).
