PC Clock Reset 5.3.2
daveh
Hello Dmitry,
We upgraded our service to the latest 5.3.2
As reported somehow the PC clock was being reset
We have now downgraded back to 5.3 and everything is running fine back to normal
We are running Windows XP and the package has been so reliable for a long long time
Thank You for your valued product we are a very happy customer for a long time as well
Cheers
Dave
Hello Dmitry
Hold off with this issue, it has happened again with the downgraded software
We also had a new copy of radio caster and radio logger installed with the new upgrade which I have deleted to see if this was affecting or influencing the issue
Both radio caster and Logger were new fresh installs and aren't yet registered
We have never run these extra modules on this PC
None of our products change the system clock... It looks like a coincidence, that something else was changed onn your PC at the time you've installed the new version. I can assure you that system clock issue is not related with RadioBOSS/RadioLogger/RadioCaster.
What is the nature of the oroblem with the clock? I'd suggest you to check your computer for viruses.
