Play Intro file on Connection
patrick.de-bruyn
Play Intro File on Connection is not working, simply nothing happens and there are no errors showed
The intro is an mp3 (C:\Users\test\Desktop\Intro Pat@Home Black Pearl .mp3)
broadcast,
show on air checked,
start playback  after connected checked,
play introfile on connection is checked,
immediately reconnect checked
RadioBOSS version 5.9.3.0
Hello, If you are using a Centova Cast server to stream your station, you can upload the intro mp3 file in your Centova Cast control panel. Make sure the file bit rate is the same as your stream bit rate. This is the best way. I hope this helps. :D
Nope i am Hosting the shoutcast stream on myselve without any software
