RadioCaster Metadata Text Replacement (Product Development Suggestion)
DJSTU
I am a current user of RadioCaster.
What I would like to see is a Text Replacement facility added into RadioCaster in order to turn nonsensical stuff into something that does make sense to end users.
For instance, in joining a stream the partial IP address shows up and is placed into CurrentSong.txt :
77.246.123
This metadata means nothing to the end user and its also not a full IP address, the last 3 numbers are missing, so it ends up just a bunch of useless numbers.
However if RC had a text replacement to take this and turn it into "We join Bill Bloggs with his latest NEWS UPDATES" how much better things would be.
Winamp used to have such a plugin which was called (I think from memory) Sqr Soft and would enable this. I cannot find that plugin without a major hunt for it on my 15 computers.
So instead I'm attaching a copy of my Text replacement section from my Magic RDS software, which does exactly the same thing I am asking for but feeds it out instead to the RDS unit as the "current song playing".
Thank you for the suggestion, we'll consider adding this feature in one of the future updates.
