Shuffle seems to not work in 7.09 beta
HMMMM
it is shuffling from all tracks not the current playlist open playlist window. When did this change? If you click track its shows the track but not the open widow suggesting it getting it elsewhere
This was not changed, and shuffle only works within the active playlist. It may "jump" to the other tabs if those tabs are activated from the scheduler (using "playlist" command) or if you use Playback Queue - queue has priority over Shuffle.
