Sweeper glitches
Because the sweepers can sometimes be inaccurate and end, say, 1 or 2 seconds prior to a scheduled event, this can result in a 1 or 2 second burst from another music file in the playlist, which is most annoying. Is there a way of avoiding this so the sweeper segues directly into the following event? If not, can the sweeper algorithm be modified to recognise this illogical situation and avoid it with a short silence to fill the gap?
It selects the sweeper so it's at least the required duration or more, but not less. It also accounts for MIX point. We'll check if there are any issues with it. Thank you for the information.
