what would be best Mix start?
dan95
Hi Dmtry,
I still don't quite understand Mix start point. Can you recommend a value when music is normalized with -23 LUFS? Also via crossfade options I set mixpoint to about -33dB.
Thx.
I suggest you to try different values until you see the result you like. A starting point could probably be -19dB.
Do I have to delete all regular start points from songs?
Start and Mix Start are totally different things, and you should have them both set for best results. If you normalized tracks after Start points were set, you can re-scan them to set Start points according to the new level.
