RadioBOSS 6.0 [beta]
if you add a song to the active playlist with drag and drop, the calculated start time is not updated.
Even if I change the song position in the playlist, the time is not updated
In the 5.9 version this time was updated on the fly even if there was no music playing in the active playlist
What do you think about implement Prelisten columns (like in Playlist) in Search Box? It would be a little easier than constantly mouse klick and Alt + R?
Excellent the requested option to delete track before File type. It continues without fading when the track is advanced or double-clicked on another track to change the current one (both tracks sound simultaneously). Still not highlighted "SEARCH" with any color in the Main Lists.
Hi
There no improvments in TRACK LIST
- Separation Artist is NOT respected
- It plays music already played when there are tons without any playing counts
Sugestion:
- Dayparts: When a song is played in a period of the day, next time it can't be played at the same period and it can only played on the next daypart that wich one can decide by choosing a period of hours
More options could be added in: file explorer > organize by. For example by track number, modification date, Album
Good afternoon from Greece. My name is George and I am a blind user. So yesterday afternoon we had a discussion with the Association of the Blind of Greece Regarding your program. There are many blind people who work in shops as DJs. Of course, the best program in accessibility is radioboss! but there is something that we hope you will incorporate even in this version. A blind user as well as a normal person without any particularity Needs control over the changes of the tracks and where the change will take place. It's very easy Well when we pre-listen A Song To be able to go where we choose to get that point on the air. This will help not only us who have vision problems but also many around the world. The radioboss is the best! So why not have this feature that will make life even easier for us? Thank you and I hope this happens soon. Yours sincerely!
What's new
  • Crossfading improved to be more smooth and precise
  • Next track is preloaded allowing for instant network stream start and speed up local track startup
  • Added separate fading duration options for Stop and Next Track
  • File type option added: skip after set file types
  • Playlist Shuffle playback mode improved: now it tries to select tracks that did not play recently
  • Comments can be added to the playlist (a comment looks like a track but can't be played)
  • Last played history for a track, can be viewed in track information panel (hover the "Last played" text) and in Music Library
  • Added filters for log window: show all entries, errors only, or scheduler related events
  • Added Search for scheduled events (Ctrl+F) to search events by action or name
  • New UI themes: Light, Flat, Dark (access them via Settings window View-Style section)
  • AUX and Overlay players are now fully featured players supporting crossfading and other features
  • Improvements in Search in the main window: faster search and load; added search by artist+title and intro
  • More columns added to the playlist window
  • Auto Intro: added "Skip after selected file types" option to prevent auto intro being inserted after certain file types
  • Added module icons to the toolbar (Ads Scheduler, Playlist Generator etc)
  • Settings backup command ("createbackup") also creates database backup (only if SQLite database is used)
  • Ability to create and restore database backup from the menu (Settings->Backup and Restore)
  • Teasers: added "Include subfolders" option to also read tracks from the subfolders
  • Added "0" button for quick access jingles
  • Added "Delete profile" command
  • Added "Copy to" playlist right-click menu option to copy a track to another playlist
  • Improved relay to playlist and back transition smoothness
  • Added API commands to control encoders (add, edit, delete encoders)
  • Added Korean translation
  • Improved high-DPI/4K monitor support
  • Manual operation: "stop after this track" button can synchronize its state with Manual scheduler option
  • User defined fields can be used in title format (%user1, ... %user5)
  • Microphone: ability to force downmix microphone sound to mono to account for cases when microphone is only heard in left channel
  • Network stream URL no longer revealed when HTTP notifications are used
  • SQLite database is now used as default storage for additional track information instead of APEv2 tag in the previous versions
  • Added user agent configuration for network stream playback
  • XML nowplaying file also includes the previous track; does not include tracks with the "Do not send title" option enabled
  • Lots of minor user interface improvements in all areas
Track Tool
  • Playback parameters (mix point, fade out, track end, level) are applied immediately to the currently playing track
  • Added track format information (sample rate, channels, bitrate)
  • Zooming does not require Ctrl to be pressed
Playlist Generator
  • Added UI themes support
  • Minor improvements
  • Fixed repeat protection when using the "Consider tracks in the playlsit window" option
Music Library
  • The Music Library has been reworked. Now it uses a database management system for information storage (instead of XML files in the previous versions). Improved search, load, and sorting speeds. More data fields are displayed in the list (columns can be selected). Drag-n-drop files from the library to Windows folders. Lots of other improvements.
  • Disabled tracks are marked in the list with color (grey background)
  • Tracks with missing or empty tag are marked with italic font in the list
Segue Editor
  • Changes are applied immediately to the playing track
  • Minor improvements and fixed bugs
Report Generator
  • Fixed: some tracks were included in the report ignoring the "Do not include in the report" file type option
Fixed
  • Fixed: some hot keys did not work in additional work zone
  • %nextsong variable included track title even if title was disabled in the settings
  • File type for line in sometimes did not work
  • Multiple playlist create UI bug fixed
  • Fixed occasional AUX playlist resize bug
  • Fixed: scheduled events sometimes were not inserted into the proper position into the playlist
  • Fixed: incorrect track mixing position under certain circumstances
  • Disable installing an automatic update for users with limited rights
  • Fixed several bugs with "Trigger mix at" feature
  • Fixed Teaser end fade/mix did not work right sometimes
  • Fixed: broadcasting statistics "froze" sometimes
  • Time announcement with "treat as voice track" option was sometimes processed incorrectly
  • Fixed: scheduled events occasionally could have same IDs
Changes incompatible with the previous versions
  • Minimum required version is Windows 7; Windows XP is no longer supported
  • Removed "Skip two or more tracks" file type option (use "Skip after file types" instead)
  • Removed legacy Playlist Generator
  • Music libraries created in previous versions will not open in this version
  • Removed "playfile" and "read_folder" scheduler commands
  • "makelibrary" scheduler command does not support full paths for library names (because libraries are no longer saved to files), only the library name must be specified
License key:
The free key expires January 15, 2021.
RadioBOSS 6.0 beta: https://dl.djsoft.net/beta/radioboss_beta_6.0.0.4.exe (10/8/2020, 35Mb)
Hi when I click on something in the cart wall it wont stop until it runs its length. There is no way of stopping it if clicked by mistake.
What's new
Track Tool
Playlist Generator
Music Library
Segue Editor
Report Generator
Fixed
  • Corrigimos vários bugs com o recurso "Trigger mix at"
  • O final do teaser fixo fade/mix não funcionou direito às vezes
  • Fixo: estatísticas de radiodifusão "congelaram" às vezes
  • O anúncio de tempo com a opção "tratar como faixa de voz" às vezes foi processado incorretamente
  • Fixo: eventos agendados ocasionalmente poderiam ter mesmos IDs
Mudanças incompatíveis com as versões anteriores
  • A versão mínima exigida é o Windows 7; O Windows XP não é mais suportado
  • Removida opção de tipo de arquivo "Pular duas ou mais faixas" (use "Pular depois dos tipos de arquivo" em vez disso)
  • Gerador de lista de reprodução legado removido
  • Bibliotecas de música criadas em versões anteriores não abrirão nesta versão
  • Comandos de agendamento "playfile" e "read_folder"
  • O comando "makelibrary" do programador não suporta caminhos completos para nomes de biblioteca (porque as bibliotecas não são mais salvas em arquivos), apenas o nome da biblioteca deve ser especificado
Chave de licença:
Se você é um usuário registrado e sua assinatura de atualização não expirou, por favor, use sua chave.
Para solicitar a chave de licença beta tester gratuita, preencha este formulário: https://www.djsoft.net/enu/beta.htm
A chave livre expira em 15 de janeiro de 2021.
RadioBOSS 6.0 beta: https://dl.djsoft.net/beta/radioboss_beta_6.0.0.4.exe (8/10/2020, 35Mb)
Por favor, poste pequenos bugs e solicitações neste tópico e crie um novo tópico para solicitações ou relatórios mais complexos.
Quem contribuiu terá um desconto significativo, de até 100%, quando a versão final for lançada. Entre em contato com sales@djsoft.net a respeito do desconto.
Esta dando erro em comandos quando inseridos na playlist. Apesar de aceitar o comando, a playlist congela e nao pula a faixa.
Segue abaixo mensagens de erro no log
Command: set autointro off
Unable to play! Error code 2 (unable to open the file/invalid server address).
Sugestion
In Music Library i would like to suggest the option to RESET ALL the playcounts and the option to CLEAR the Last Played but would be usefull if you add the HISTORY of the songs by right clicking a title, chosing HISTORY and open a browse with the dates/hours of the last 5 times (or more) it played on RBoss.
Completely disable replay control rules, and the log keeps saying the same thing.
In addition, the playlist generated was 2 hours, when in reality it should be 18 hours.
The source is m3u playlist
Also on that built playlist I am seeing that the metadata of the track does not match with the playlist.
I attach the generated playlist
It would be interesting to be able to see the AutoIntro file that is going to be inserted, in addition to giving the possibility to manually cancel it :)
- Commands when in "Event> Multiple event action" and in "Playlist generator> Category> Track source" then takes long time to execute. About 2-3 sec. In 5.9 it takes milliseconds. (6 and 5.9.4 are one same PC).
While commands as a single Event execute instantly.
Yes there indeed is a delay between executing the commands, will be fixed in the next update.
- In crossfades for some file types I turn on "Override previous track mix". But when they playing it always ends with fade out? In 5.9.4 there is no fade out.
It overrides the mix, but does not change fade out. If you also have "Start fading out on mix" (for the previous track) the fade out will be changed.
- In Event> Multiple event action if there more lines the lines can be dragged.
Can the same be done for lines in Playlist generator> Category> Track source?
The sources are anyway loaded to a single list when playlist is created, so the order does not matter, why drag the items?
It appears that mapped drives are completely ignored by Release 6. Will this be addressed?
This does not seem to reproduce here. It shows both shared network folders and network drives. They are available in the drop down list, or when you select "This PC" they will also appear in the main list. Please see the image attached.
Good idea - will be implemented soon.
Does it always happen, the two trackis playing? We do not seem to be able to reproduce it here. Can you please send a screenshot of Settings->Playback->Fading and Crossafdes windows?
The found track is marked with a selection, and is typically located at the bottom of the playlist.
There were no changes in the Track List feature compared to the previous version. The selection is random and it tries to play tracks that were not yet chosen.
Yes, this is something we plan on developing in the future versions.
Sorting by track number or other tag information will rerquire reading tags and it can significantly slower down the speed of file listing. If you need advanced sorting and searching features, the Search feature could be a better choice: https://manual.djsoft.net/radioboss/en/search.htm
Do you mean track seeking while prelisten or while on air?
Thank you for letting us know about this bug.
2nd time that this showed on my screen
Please click Details, then Send Bug Report button, this will allow to see what is the problem. Also ensure that you use the most recent RadioBOSS 6.0.0.4.
If you add commands to the playlist, use the Playlist->Add command feature, and if you modify playlist manually using text editor, include .command after the actual command, e.g. set autointro off.command
You can reset the playcount: https://www.djsoft.net/community/threads/reset-playcount-in-radioboss.6299/ and an option to also clear Last Played will be added too in the future versions. The played history column will be added to the music library.
Thank you, it looks like track metadata is indeed wrong.
Multiple selected tracks cannot be dragged in the playlist. This is a bug?
Currently it's a limitation, only one track can be dragged. If you need to move multiple tracks it could be better to use Cut/Paste features.
