Not yet, sorry - it's planned for the future versions (RadioBOSS 5.5 I think).nelson c said:Dmitry for Sweepers already taken into account the time cutout of silence, or still not been implemented? Thank you
Ok, thanks.djsoft said:Not yet, sorry - it's planned for the future versions (RadioBOSS 5.5 I think).nelson c said:Dmitry for Sweepers already taken into account the time cutout of silence, or still not been implemented? Thank you
This is next to be added?djsoft said:Currently it doesn't take into account start/end and gap killer - in one of the future versions it will.nelson c said:I just realized that the time has not fill the account the beginning and end of ad space
If you use alternate tracks, this is possible. It will insert all the ads that are assigned to the block, regardless of the duration.there is a bug in the commercial block filling. In my tests, I see nonsense sometimes I see 7 minutes blocks when the set time is 5 minutes. Other times if it works relatively well ..
As I recall, the problem is with the number of combinations, and the processing required, "select 4+ tracks from N sweepers" is much faster than selecting only 3 tracks. Perhaps we can find a better algorithm... But having more than 3 sweepers at the end of the ad block - how will it sound?Another question: Limiting sweapers to 3 may be a meaningless limitation
I didn't use alternate tracks, that's the problemIf you use alternate tracks, this is possible. It will insert all the ads that are assigned to the block, regardless of the duration.
If they are separators it would be a problem. But we also have music in our sweperes folder, for longer fills. There would be no problem thereIf you use alternate tracks, this is possible. It will insert all the ads that are assigned to the block, regardless of the duration.
There could be a bug. It will be addressed in one of the next updates, when AdsScheduler is reworked.I didn't use alternate tracks, that's the problem
Do you mean it should insert multiple music tracks? In this case, the "sweep" time will be around 10 minutes...If they are separators it would be a problem. But we also have music in our sweperes folder, for longer fills. There would be no problem there
In the source folder there are files of all kinds. It could be 2 songs and 3 separators (haphazard) for example if the time to fill in is longThere could be a bug. It will be addressed in one of the next updates, when AdsScheduler is reworked.
2 songs + 3 separators will be about 8 minutes. What is the duration of the advert block? It seems to be untypically huge.In the source folder there are files of all kinds. It could be 2 songs and 3 separators (haphazard) for example if the time to fill in is long
Our setup was 6 minutes. (Never an advertising block lasts so long) But it led to the possibility of generating sweapers with music in the repeaters. With the intention that the fill is as perfect as possible.2 songs + 3 separators will be about 8 minutes. What is the duration of the advert block? It seems to be untypically huge.
Approximately 2 or 3 minutes of advertising.Out of 6 minutes, most part will be the Ads? In this case, why so many sweepers? Currently it chooses two, so it can select a song and thn a short sweeper, to try to match the duration exactly.
