Bugs report (radioboss 6.1.2.1)
JeanXeb
Hi radioboss,
After a long time without restarting the software, 2 bugs appear.
The problems were already apparent on previous versions.
-The software adds 5 minutes in the programmed actions (see capture1)
-Second bug the option button no longer launches the parameters but the recorder. (see capture2)
Cordially
We've had similar reports from some of the users but were never able to reproduce those bugs here. How long did it run before it happened? Do you use the computer locally or you connect to it using Remote Desktop?
Yes I use Remote Desktop.
I would say after 5 days.
Another bug the cleanup freeze at 50% in music library
All reports we've seen about it involve Remote Desktop. It looks like it causes those UI bugs. Unfortunately, I can't offer you any solution for it. Looks like a bug in the underlying libraries that RadioBOSS uses - so we need to wait when/if it's fixed there.
Does it happen always? What happens if you restart it and start cleaning again?
