RadioBOSS 7.0 [beta]
When I manually insert a tracklist and select a file randomly, shouldn't it continue to play random tracks when I select run now? Is it meant to play only a single track?
Track List plays only one track: https://manual.djsoft.net/radioboss/en/using_track_list.htm
If you need it to continue playing, enable the Repeat Playlist option. This way, you can build a rotation using Track List items.
I notice that English is the only language for certain Playlist Generator windows even if the translations were made in the "lang.ini" file.
Thank you, this will be fixed in the next update.
Have to say this has been the best Radioboss version I have used yet, No hardware or software issues and I love it! I just hope to get a decent price on the upgrade as the beta key expires (because I forgot my registered key) :)
You can access the customer area to get/restore your key: https://www.djsoft.net/customer/
Please contact support@djsoft.net if you're interested in a discount.
Please, could you tell me why the "star earlier to make it end at start time" function does not work for me with the add a track from a playlist/folder command.
It only works with regular files or playlists, special items like Track List or selecting track from a folder, are not processed.
What I want to achieve is for a song to play before the scheduled time and end at the specified time so that another event also scheduled at the same time is loaded and played.
Looks like you should use the Sweeper feature: https://manual.djsoft.net/radioboss/en/sweepers.htm
"Hello.
As an amateur, I did not test many features in the RadioBOSS 7.0 version, because I simply do not need to use them on a daily basis.
However, I noticed a few things.
I will also add that I use this application with the help of the NVDA screen reader and speech synthesis, so I have the Accessibility function enabled.
1: I really like the improvement of the accessibility of various sliders.
Now it is known which slider corresponds to which function and the values are also read correctly.
2: On a daily basis, I do not use the playlist generator or the advertising schedule, but out of curiosity I decided to look at these functions and noticed some encoding error, which causes the Polish diacritical marks used in some commands to be displayed incorrectly or more precisely read incorrectly by the speech synthesis.
3: A funny translation flaw probably still from version 6.3:
In the settings in the Transmission section there are 3 buttons for adding, editing or deleting server addresses, which I connect to in order to broadcast the show.
While the buttons: "Add" and "Edit" are read in English, the "Delete" button is translated into Polish.
It would be good to translate the labels of the other buttons as well, although it is not particularly troublesome when they are not translated.
4: Suggestion:
I suggest the possibility of automatic start of recording the stream along with the start of the playlist.
Thanks to this, the start time of the recorded file would be equal to the start time of the show and the next elements in the image file .cue would also be correctly indexed, and the show would be recorded from the very beginning.".
Changes
  • Fixed: sometimes played tracks were not removed from the playlist in Queue mode
  • Other fixes
Great, that's sorted out as well. I know it's risky, but I was impatient, so No. 7 has been up and running on our radio for about ten days now. Apart from these few minor issues that have been resolved, I can't find any other mistakes.
  • The advertisement numbers in the fields have made my job much easier.
  • Proportional selection in PLGen has drastically improved the music on the radio. Now everything is much more consistent.
  • Being able to assign days of the week to each start time in the event's start time list is also a great feature. Now I don't have to put the same event in multiple schedulers anymore; everything goes into one.
I hope this will be addressed in No. 8.:
Timing when a song/jingle can play. Or in this case blocking a certain time.
It is useful, for example, for songs that have a heavy vocabulary and are not suitable for broadcast during the day.
Or for a special jingle that only goes at night or on a certain day (weekend jingle, sunday jingle, etc.).
New little translation problem. It's always in the Playlist Generator => Category.
This time, you have to go to the priority tab. Click on the “+” at the bottom right.
The particularity of the problem is that I cannot find the original version among the 4 ".ini" files. So I can't translate these elements...
RadioBOSS 7.0.0.1 beta (11/19/2023)
Changes
  • Fixed random selection in Playlist Generator
  • Fixed up/down arrows in the categories list (Playlist Generator)
  • Minor improvements in the Teaser window
  • Fixed waveform didn't work in the Voice Track recorder
  • Fixed flicker in Event Overview window when using dark theme
  • Fixed playlist generator performance issues
  • Improved Ads Scheduler grid performance
  • Grid in Ads Scheduler always shows the number of ads in the block
  • Ads Scheduler: extended priority range is now optional
  • Playlist Generator improved the priority rule window
  • Playlist Generator: fixed dark theme for playlist selection window
  • Advanced option added: streaming server stats check interval
  • New options added to hide toolbar button groups
  • Fixed various other bug reports
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.1.exe (11/19/2023, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.1_x64.exe (11/19/2023, 38MB)
RadioBOSS 7.0.0.2 beta (11/24/2023)
Changes
  • Track Tool UI minor improvements
  • Ads Scheduler: colors for the grid cells (checked/unchecked) can be changed in the Settings window
  • "Check all" checkbox for week days in the additional time configuration window for event
  • Rating hot keys in the playlist changed to Ctrl+Numpad0..9, Ctrl+Numpad- clears rating
  • Event overview: filters can be applied to only show specific events
  • Event overview: analysis data can be exportewd as CSV file
  • Playlist Generator: priority rules based on Date Added and Last Played allow specifying fractional values
  • Fixed: mouse cursor did not hide in video window sometimes
  • Fixed: web browser Ctrl+V and other shortcuts didn't work
  • Fixed event overview bug: duration for some events was incorrect
  • Fixed priority rules save/load to file
  • Other minor fixes
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.2.exe (11/24/2023, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.2_x64.exe (11/24/2023, 38MB)
RadioBOSS 7.0.0.3 beta (11/29/2023)
Changes
  • New tag fields (album artist, composer etc) added to Track Tool and the tag editor in Music Library
  • Tags window redesigned: added filter and improved editor
  • Crossfade option: limit Mix point to end before following track Intro ends (Advanced Settings)
  • Fixed: cart wall was not visible on the left zone when dark theme was used
  • Fixed: comment filter in playlist generator did not work properly
  • Fixed: Playlist Generator - editing priority rules made changes to the category even if Cancel button was pressed
  • Fixed: Playlist Generator - priority rules list save/load to a file
  • Fixed: Ads Scheduler - cell color configuration bug
  • Playlist Generator: improved priority rule window UI
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.3.exe (11/29/2023, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.3_x64.exe (11/29/2023, 38MB)
RadioBOSS 7.0.0.4 beta (12/5/2023)
Changes
  • Track Tool: added vertical scroll when the window height is not enough to show all tag fields
  • Fixed bug related to "Start event earlier..." feature
  • Playlist Generator: increased quality of selection for "proportional category"
  • Show currently the playing track in window title bar and in taskbar hint (advanced option)
  • View/Style - waveform color option added
  • Ads Scheduler: improved performance for grid and creating playlists
  • Voice activated microphone: fixed "Next track after mic off" option
  • Fixed: microphone bed did not loop
  • Fixed multiple minor bugs
  • Minor UI impovements
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.4.exe (12/5/2023, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.4_x64.exe (12/5/2023, 38MB)
RadioBOSS 7.0.0.5 beta (12/10/2023)
Changes
  • Advanced option added: ignore accented characters when searching tracks in library
  • Fixed occasional flickering when RadioBOSS was accessed via RDP
  • Fixed: tag for some m4a/mp4 files was not properly read
  • Advanced option: restart jingle when hot key for playing jingle is pressed
  • Intro countdown is preserved when a track is seeked
  • Track Tool: tag fields list on the left can be scrolled with a mouse wheel
  • Search: added Tags column
  • Minor UI improvements
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.5.exe (12/10/2023, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.5_x64.exe (12/10/2023, 38MB)
RadioBOSS 7.0.0.6 beta (12/15/2023)
Changes
  • Render to playlist: do not include selected file types in cuesheet option
  • Music Library: the check tracks option allows to copy selected tracks to a folder
  • Recent tracks artworks can be saved to a folder
  • Next track artwork can be saved and uploaded to FTP
  • streamarchive command with file name specfiied, uses a second recording instance
  • More options can be configured for Nowplaying bar display (Settings/View/Style)
  • Ads Scheduler: checkboxes in grid (instead of track count in the block) can be enabled in Settings
  • Fixed various bugs; minor improvements
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.6.exe (12/15/2023, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.6_x64.exe (12/15/2023, 38MB)
RadioBOSS 7.0.0.7 beta (12/17/2023)
Changes
  • Fixed crash/restart bug
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.7.exe (12/17/2023, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.7_x64.exe (12/17/2023, 38MB)
RadioBOSS 7.0.0.8 beta (1/7/2024)
Changes
  • Cart wall: Caps Lock can be used as a hot key modifier to start cart wall items by pressing CapsLock+Key combination
  • Playlist Generator: added search (Ctrl+F) in the Load Preset window
  • getfile command: added /move option to move file to a set folder after playback
  • Quick Jingles: pressing the "minus" key stops all playing jingles
  • Tag editor: new fields (album artist, copyright, etc) can be edited for MP3 and other file types
  • Style option: set selection style for secondary lists (events, log, search)
  • Ads Scheduler instances can be named (configured in the Settings window)
  • Web browser: protocol is auto appended when address is entered without it
  • Track Tool: extended Zoom range
  • Fixed: nowplaying/last played/next track font style was not applied
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.8.exe (1/1/2024, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.8_x64.exe (1/7/2024, 38MB)
RadioBOSS 7.0.0.9 beta (1/21/2024)
Changes
  • Fixed: "run in" incorrectly displayed for some events with multiple start times
  • Fixed: Playlist Generator "In order" selection did not use the position configured in the category
  • Fixed: crash when saving tags for certain files
  • Fixed: DTMF Exit did not wait for tracks to finish playing when "Overlay playback" option was used
  • Call encoder editor window from Statistics window (double click in the list)
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.9.exe (1/21/2024, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.0.9_x64.exe (1/21/2024, 38MB)
RadioBOSS 7.0.1.0 beta (1/29/2024)
Changes
  • Auto Intro: added intro tracks filters
  • Auto Intro: added rule check order option
  • Music Library: redesigned tag editor window; track artwork can be edited
  • Added HTTPS streaming support for integrated server
  • Added fade out option when the relay is turned off
  • Time Zone option changed to Clock Adjust option allowing more gradual control
  • Fixed web browser incorrect https:// addition
  • Fixed: occasional short UI freeze on broadcasting encoder start/stop
  • Minor improvements and bugs fixed
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.2.exe (1/29/2024, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.2_x64.exe (1/29/2024, 38MB)
RadioBOSS 7.0.1.3 beta (2/2/2024)
Changes
  • Skip options in file types are now processed in advance to correctly display next track
  • Ads Scheduler: improved event configuration window
  • Music Library: added prelisten to Track Properties window
  • Fixed nowplaying font bug in AUX players
  • Fixed applying styles for Nowplaying bar
  • Fixed adjust clock bug in settings
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.3.exe (2/2/2024, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.3_x64.exe (2/2/2024, 38MB)
RadioBOSS 7.0.1.4 beta (2/5/2024)
Changes
  • Playlist Generator: improved random track selection algorithm when priority rules are used (the point is more uniform selection avoiding "favorite" tracks problem)
  • Scheduler: fixed bug with multiple start times and days of week, sometimes events started when they should not
  • Auto Intro: added command to copy a rule
  • Ads Scheduler: fixed checkboxes not visible in some themes; error when changing themes
  • Minor UI issues fixed in various areas
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.4.exe (2/5/2024, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.4_x64.exe (2/5/2024, 38MB)
RadioBOSS 7.0.1.5 beta (2/12/2024)
Changes
  • Fixed a bug when skipped tracks were not removed with Queue option on
  • Playlist Generator: fixed a rare issue with repeated tracks
  • Fixed: scheduled event started when multiple start time option was activated but no start times defined
  • Fixed event duration limit option sometimes skipped the following after an event track
  • Stop command now takes into account "Fade out on stop" option
  • Ads Scheduler: improved grid display
  • Improved Shuffle mode operation after scheduled tracks
  • Other bugs fixed; minor improvements
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.5.exe (2/12/2024, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.5_x64.exe (2/12/2024, 38MB)
RadioBOSS 7.0.1.6 release candidate (2/16/2024)
Changes
  • Other fixes
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.6.exe (2/16/2024, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.6_x64.exe (2/16/2024, 38MB)
What are those of us who lost our password yesterday going to do? They send us a new password because they change the version every 24 hours. regards
Perhaps for the end (if it's not too late) or for some future version - in the Ads Scheduler, darken every second column by day. Just like the rows in Ads window. For better clarity, if the columns are long, it would be easier for me to distinguish days. Sometimes I mistakenly place an Ad on the wrong day.
Something like this:
Yes, I think the same thing. This would be good because I also have jingles that should only play at certain times of the day (Example: good morning or good afternoon...).
The same goes for music that has musical and vocal particularities. You have to put them on at certain times of the day and not at others. My current solution is to create new categories.
With this suggestion from tomimatko, I will be able to optimize my rotations and see more clearly.
I also offer an additional function when creating a category in the Playlist Generator: take into account custom fields (we can currently create 5). For example, in my custom emotions field, a happy song should follow another happy song.
I did the same thing, I have the same category in several versions. With jingles for morning, weekend, evening, night, etc. So we have a fairly long list of Events in the Scheduler even though they only differ by the jingles.
i have had no issues with the 7.0, No hardware issues and no problems with the program, I think this one is a winner! just hope I get a good price on the upgrade!
Your first post in this beta period and you ask for a discount ?
Exactly my humor
I think these discounts or account extensions should be earned by actively participating
This is my humble opinion
Esta es la primera y única vez que publicas algo en esta sesión beta y solicitas una clave.
Sólo mi tipo de humor
Con todo respeto, he pasado mucho tiempo en los foros, no sé para qué voy a hacer algún comentario, si la mayoría encuentra algún problema en cada versión. Hice una traducción mucho más comprensible y Dimitri no aprobó mi versión, pero luego he visto que las versiones actuales tienen mi traducción, porque se las envié a una persona que está en el foro y veo que la han aprovechado. Un puñal en la espalda. Agradezco tu comentario. saludos
This is the first and only time you have postet somthing in this beta session and asking for a Key
Just my kind of Humor
As in my previous RB beta use over the years, if I had found a problem I would have discussed it. Are you asking me to report imaginary problems? I think not.
What needs to be improved if the slider name is value are being read?
Where does it read it incorrectly, is it the user interface translation issue?
Thank you, will be fixed.
You can add commands (menu Playlist->Add command): streamarchive on at the beginning of the playlist, and streamarchive off at the end, this will control the recording.
More about the commands: https://manual.djsoft.net/radioboss/en/scheduler_commands.htm
You can buy a full version, or update your existing key if you have purchased it before.
Thank you for the suggestion, this will be assigned for the next minor update, a change like this is not a quick add, there are potential issues with dark theme and item coloring, this will further delay the 7.0 release which is already delayed more than it should.
Currently this can be solved by using a different playlist generator templates for different parts of the day.
Yes, this is the correct way to handle this, different categories and presets.
Custom Fields are mostly used for Reporting - for cases like this (specify mood, speed, and other song properties) you should use Tags: https://manual.djsoft.net/radioboss/en/using-tags.htm
And there will be a new feature in the Playlist Generator to specify rules for Tags - what tag can/should/must follow another and so on.
Por favor, escribe en inglés.
With all due respect, I have spent a lot of time on the forums, I don't know why I am going to make any comments, if the majority finds a problem with each version. I made a much more understandable translation and Dimitri did not approve my version, but then I have seen that current versions have my translation, because I sent them to a person who is in the forum and I see that they have taken advantage of it. A dagger in the back. I appreciate your comment. greetings
