This is a bug in newer versions, will be fixed in the next update.I repeat, it didn't happen to me like that
With this option, do I have to add all the artist names that I have in my music database? one by one..This is a bug in newer versions, will be fixed in the next update.
Also, for the case on your screenshot, there's a better feature: Multiple Artists.
The option allow you to specify separators like "ft." and it will automatically separate artist names based on that.With this option, do I have to add all the artist names that I have in my music database? one by one..
Is there an option to make it automatic?
Okay, I understand.The option allow you to specify separators like "ft." and it will automatically separate artist names based on that.
Nothing else needs to be done - only specify the separators list. What RadioBOSS version do you use?It is configured. But the artists still repeat. Do i have to do something else?. so it doesn't keep happening
Okay, I've always had it active. but even so he repeats artists to me as the attached image shows. At the moment I am only testing the latest version.Nothing else needs to be done - only specify the separators list. What RadioBOSS version do you use?
Do you have tracks properly tagged, so that Artist field contains artist name - or the tag fields are empty and the artist/title are extracted from the filename?Okay, I've always had it active. but even so he repeats artists to me as the attached image shows. At the moment I am only testing the latest version.
Yes, I always try to have my database in order. I attach a capture that shows part of how it is organized...¿Tiene las pistas correctamente etiquetadas, de modo que el campo Artista contenga el nombre del artista, o los campos de etiqueta están vacíos y el artista/título se extrae del nombre del archivo?
Please ensure that none of the categories in the Playlist Generator override (or ignore) repeat protection rules. Currently we can't reproduce this issue here.Yes, I always try to have my database in order. I attach a capture that shows part of how it is organized...
Yes, everything is in order. What occurs to me is to reset the date of last reproduction of all the songs so that the program has fewer problems when generating the playlistPlease ensure that none of the categories in the Playlist Generator override (or ignore) repeat protection rules. Currently we can't reproduce this issue here.
Playlist Generator takes this date into account for repeat protection.What occurs to me is to reset the date of last reproduction of all the songs so that the program has fewer problems when generating the playlist
