Override previous tack mix point set by dB Level
reyfmde
Hi,
is it possible to reset the track mix point that's has been set by the "Trigger mix at: -3dB" by some seconds? For example set the mix point 2 seconds early then the -3dB point.
The "Override previous tack mix point" option set the mix point at the end and bypasses the "trigger mix at" option.
If it's not possible, could this be implemented in a newer version? It would be really useful for jingles so they blend in better with the songs, but still keep the clean fade when no jingle is played.
Best regards
If you override previous track mix, then it simply sets the new value - disregarding the mix value a track had (no matter fixed or detected). Currently we do not plan on changing this, as it seems way too complicated the way you propose it to work - I'm sorry.
