Short audio burst using 'stop after current'
WondereWouter
This problem occurs when we use 'stop after current'; at the end of the fade, the audio shoots up to 100%, just before the song is stopped, causing a short burst of sound. This is very annoying. It sounds like the DJ is making mistakes all the time.
When the list is playing normally, the fades are fine.
Anyone any idea what can be the cause?
Grtz,
Wouter
This does not reproduce on the latest RadioBOSS 6.1.0.5 and previous 6.0.4. What version do you use?
WondereWouter
Upgraded to version 6.1.0.5. Same issue persists.
Only and always @ stop after song. It seems like the fade is being cancelled at the very last piece of the song, causing a short 'blip', recognizable as the song 's end @0db.
Please check the fading settings in Setting->Playback->Fading, try adjusting the option for "Fade out on stop".
WondereWouter
The problem is indeed solved by adjusting 'fade on stop', but only when it is set to 0s. Every other value results in the short burst of audio at the end. Fade out out on stop seems to be buggy.
This error does not reproduce here, regardless of the fade out on stop fade value, it always properly stops the track without any side effects. At this point, it can't be fixed, I'm sorry.
