Solution to turn off streams based on a .bat or .cmd
JeanXeb
Hi,
I would like to know if there is a solution to easily turn off previously selected streams in a .cmd or .bat.
Because I have two instances that play on two remote servers (main/backup) and when I import the settings into the backup studio, there are only the icecast streams that I have to manually restart correctly ...
Cordialy,
This is a solution that I had already tried but it does not work.
I have multiple streams to turn off and on
Would it be possible to extract the streaming information from player.ini into another .ini (stream.ini) ? (or other)
In the objective or two instances (main studio) and (backup) when importing the parameters do not modify the different streams.
This is possible using the API: there are getencoder, setencoder, and deleteencoder commands.
I know the API system but would it be easy for you to extract the streams of player.ini in a new file stream.ini ?
It would be so much easier to administer between the primary and backed up instance (Especially when you have several...)
It's a text file, you can copy a section where encoders are stored and insert it into the computer where you need it imported. RadioBOSS needs to be closed when you modify player.ini file.
Jean I posted something o here to do that on a website using PHP, RB generates a XML report with all the session fields except %lyircs which we wait for.
