DesertIsland
Hello.
I came across an issue with Tags but I am not sure if it is a bug or just how it works.
I had 2 different tags ( "SOUL R&B" and "ROCK'N'ROLL") they both tag to the file OK,
but I found that these two do no work is search ( neither the Search Tab or in the music library)
they both return zero results.
I worked out that it was the "&" and the " 'N' " .
When I used "RnB" and "ROCKnROLL" they worked fine.
So I presume that I should not use non-alphanumeric symbols in the Tabs?
