Next Track display issue still present in RadioBOSS 7.2.3
Hi,
I’m now using RadioBOSS 7.2.5.0, but the Next Track display issue is still present over RDP.The Next Track title can remain stuck on the previous track. If I minimize the RadioBOSS window and restore it, the display immediately refreshes and shows the correct next track.So the issue still seems to be related to UI repainting/redrawing after RDP use.Best regards,Miklós
Can you please check if you keep the window open, will it update the next track after the currently playing track is finished?
I tested it for several tracks with the RadioBOSS window left open, and the Next Track display updated correctly every time. In my case, the issue seems to appear after minimizing/restoring the window over RDP. However, another user reported the same issue without using RDP, so it may be a more general UI refresh/redraw issue rather than being RDP-specific.
Thank you for the update, we'll see what else can be done about it.
