We're looking for software for streaming a talk network. There are several requirements that must be met. Please let me know if RadoBOSS will do these.
[list type=decimal]
[*]Events must be able to start at exact times or at floating times, based on the program.
[*]The software must be able to turn off programs that are playing from the hard drive and enable the live input from the sound card. That is, replays stream 24/7, but from 9 until 11, the sound card input is enabled, and the replays are silent.
[*]If there is only one replay, it must repeat continuously unless it is stopped manually or by a timed event.
[/list]
I've spent a few minutes with the manual, but please point me in the direction to tell RadioBOSS how to enable the live input, as above.
[list type=decimal]
[/list]
