josedisco
Good evening, I wanted to see if it is a mistake or what the problem would be.
After a power failure, the computer started automatically but radioboss 6 did not start with windows.
In preferences, the start with windows was marked and the check mark to continue playing the playlist was marked. Whenever I make modifications I make a backup copy of the preferences. (with windows startup checked) but when restoring from a backup this option is unchecked.
From already thank you very much.
Jose Disco
Argentina
Jose Disco
Argentina
