Contribution: Remote Control for RadioBOSS
Obrigado :). Luego esa classificação
é tomada pela Playlist Gen Pro e gera uma playlist para RadioBOSS. Também a partir deste aplicativo você pode inserir músicas na lista de músicas do RB. Eu te deixo uma vista.
Tudo isso funciona graças à API do RB!.
Estou abocado para isso, nesses momentos estou di?ando o aplicativo para Android para o sistema que você deseja desenvolver.
PD: Dejo lançou a última versão do LocuWeb, com várias melhorias :D. Há muitas coisas sem terminar..
NELSON, ESSE PROJETO CONTINUA?
In the future I translate it to English. (it was in Spanish, today I started with translation) ;)
It works with internet (if open the corresponding port in your router). It doesn't work as well as locally. (there is a small delay of half a second sometimes). but it is still much better than teamviewer :)
some things "work" but are not programmed correctly.
For example the search XML hanging around the program when large libraries are used.
If someone wants to collaborate Delphi knowledge , we could do more interesting things ! .
Hi Nelson,
if You are still interested in collaboration, I have many years of Delphi experience but I'm not a professional developer. My first Delphi was version 5, had many private projects build with version 2005 Architect, and am currently using version 11 CE. In which version did You build that LocuWeb application? I thought about building an application like Yours to use the RadioBoss-API, because RadioBoss unfortunately does not support remote voicetracks yet, but then I found You in the forum, so maybe we can do that together!
Hi Nelson,
Hi, it's programmed in Rad Studio. I don't have much time to work on this at the moment. But I can guide you if you'd like to work on this project.
Hello Nelson, how are you?
While testing I found these errors:
1 - When monitoring a track and changing the order of the files in the list, the following error appears:
2 - When the list is playing and you want to change the order of the playlist, this error appears with multiple windows.
3 - This error appears when you press play without selecting a track from the list, it should tell the person to select a track.
4 - When trying to change the order of the list, these two errors appear continuously.
first:
And then this one:
3 - When stopping, there is a delay of approximately 4 seconds on the local network.
It stops on the remote PC, but not immediately on locuweb.
How to add a specific route to music search? Can a local network route be placed?
first:
And then this one:
To solve it I would need videos where this error is generated
Wow... very, very interesting.
I tested it localy and it works perfectly.
Do you have an english config file? :)
Does it work (remote) on the internet?
Most of these "config" files (whether for 7 Days to Die XMLs or Unreal World scripts) are written in English by default because that is the standard for the game engines they run on.
  • For 7 Days to Die: The files in Data/Config (like recipes.xml or blocks.xml) are already in English. If your game is displaying in another language, it's usually just the Localization file translating those English tags.
  • For the Phantom 3: If you are looking at the .txt or .bin files used for the "Distance Limit" hack or parameters, those are strictly in English/hex.
If you tell me exactly which file you are looking at (the name of the file and the game/device), I can provide you with a clean, commented English version of the code.
