UTF‑8 Encoding Problem with Accented Characters
JeanXeb
Hi radioboss
I'm running into an issue with metadata encoding. Titles containing accented characters are not displaying correctly.
For example, the title “Mel Tormé – Right Now” ends up corrupted in the metadata. (Mel Tormà - Right Now)
The attached files illustrate the problem, which is surprising since all my data is properly encoded in UTF‑8 on my side.
Thanks in advance for your help.
Probably the bug is somewhere else, as RadioBOSS does send UTF8 titles properly. What streaming server do you use? If you open the server's admin page, does it show the correct title there?
In the Icecast2 Status page, the issue is also present on the streams (see the attached screenshot from our Icecast2 server).
We have several proprietary servers as well as Infomaniak, for example, and the problem is present everywhere.
I forced UTF‑8 on our proprietary servers, but I still see those strange characters.
We can't reproduce it here, with properly configured server (Icecast and UTF8 enabled for mount point) and UTF8 selected in RadioBOSS, any international characters are properly displayed.
Thank you for your feedback. We will run tests on other servers to understand the source of the issue.
Thank you for taking the time to reply and for performing the tests.
